Announcement
Collapse
No announcement yet.
Low speed radiator fan resistor
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Low speed radiator fan resistor
    I'm posting for BigRob who is having trouble posting.
    Originally posted by BigRob
    The Issue I was looking for info on was the low speed resistor on a 95 contour 2.0l engine, where might I find a replacement for it, part number . The problem is cooling fan only comes on when when into the red. I searched the forums and the info I dug up leads me to believe this low speed resistor is the culprit(maybe) just looking to fix it . Thanks in Advance. BigRob
  • #2
    Read this thread and link for some good info.
    http://www.contour.org/ceg-vb/showth...light=resistor
    Comment
    • #3
      Yes I did check out that thread. Lots of good info there, but I got excellent help from Bill Jenkins over at Team Ford locating the part numbers I needed for the low speed resistor.
      For anybody else that needs this info ,here it is.
      cooling fan resistor(located on the lefthand bottom side of the fan shroud
      > 1995-96 F5RZ-18591-A
      > 1997-00 3M5Z-18591-BA
      Fan relays for 1995 Ford Contour 2.0 engine
      High speed
      F5RZ-14N089-CB
      Low speed
      F5RZ-8B658-A
      Fan Wire Harness
      F6RZ-8C290-S6A
      I'll have to post later after repairs are completed
      1995 contour 2.0 A/T
      Comment
      Working...
      X
