Announcement
Collapse
No announcement yet.
need new engine mounts
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • MadDog
    started a topic need new engine mounts
    I get a lot of slop in SVT when I shift and it "feels" like the motor mounts are shot. The vehicle has 250K miles on it, so no surprise. If I understand correctly, the best rear motor mount is one PRT sells and for the front right motor mount (neat the PS pump), is it possible to rebuild the stock part with a new rubber damper, or is buying a whole new part the only way to go ?
    thanks,
    Mad Dog
  • MadDog
    replied
    I have been looking for motorcraft parts on Ebay, if thats any better.
    Mad Dog
    Leave a comment:
  • ScotSHO
    replied
    Sooo, where should one buy their parts now?
    Leave a comment:
  • amc49
    replied
    Pretty much ALL aftermarket OEM replacement mounts are crap...............that including Westar, DEA, Anchor, and Napa, they use cheap Chinese hard as rock rubber and the pass side hydro types have lifespans in hours not years. Many go in as little as 6 months and can shed the upper pieces to have them run through your belts and damage.
    I'm late but there it is, I used to sell the parts OTC.
    Leave a comment:
  • MadDog
    replied
    For the rear motor mount, is Anchor or Westar a good manufacturer ?
    Mad Dog
    Leave a comment:
  • SuperRob
    replied
    Originally posted by MadDog View Post
    You bad dog ! I just saw it on the website a few weeks ago but couldn't get to it until last Friday. Did you get anything good off of it ?
    Mad Dog
    I picked up a sunroof motor and a couple other little things but it was pretty beat to hell.
    Leave a comment:
  • MadDog
    replied
    Mad Dog
    Leave a comment:
  • SuperRob
    replied
    As long as your only pulling the front or rear you will be ok but obioulsy don't remove the side mounts. You missed an SVT Contour that had been there for a few months. I pulled a few things from it.
    IM still here. I went to the Pull a Part and there are a few contours on the lot. If I try to get the rear engine support off one of these, do I have to support the engine first ? I kind of hate getting under a under a junker on a lot.
    Mad Dog
    Leave a comment:
  • MadDog
    replied
    Mad Dog
    Leave a comment:
  • SuperRob
    replied
    I thought about filling my rear restrictor with 80, but if PRT would make one that would save me some hassle. Given the miles on the car anything is likely to go. Having said that, it still runs great.
    thanks,
    Mad Dog
    Are you still in Augusta,GA?
    Leave a comment:
  • MadDog
    replied
    thanks,
    Mad Dog
    Leave a comment:
  • cclngthr
    replied
    Originally posted by crewchiefpro View Post
    I have never seen the motor mount by the power steering fail. It is always the Roll Restrictor behind the transmission or the front mount that goes. The one over the transmission is prone to fail as well. You can rebuild the roll restrictor yourself with urethane, not too difficult. Get the 70 or 80 hardness type.
    I replaced both upper mounts on mine since both were bad. The upper engine mount can go bad if the lower mounts are also bad.
    Leave a comment:
  • crewchiefpro
    replied
    Leave a comment:
Working...
X
