Page 1 of 2
1 2 LastLast
Results 1 to 10 of 11
Thread: Loud Humming noise while driving
    Default Loud Humming noise while driving
    Alright, i have this really loud noise coming from the front end when i drive.
    It gets noticeable above 20km/h, but kinda disappears after 120km/h...
    Now, the sound is kind of a humm, and it gets pretty loud around 80 (50 mph) it goes with wheel speed, not engine speed (when i put the car in neutral and coast, it continues, and it just gets higher pitched as i go faster)...
    It is there when i drive in a straight line, and when I corner left, but kind disappears (for a few sec) when i corner right.
    I know its not tire noise because it does the same thing on dirt as it does pavement.
    I think that it may be a front wheel bearing, or cv joint?
    1998 Contour, 2.0L 5-speed
    Jul 2001
    Humble
    10,828
    the sound you are describing is almost positively indicative of a front wheel bearing. the bearing is likely the front passenger side as the noise goes away when you turn right and UNLOAD the weight off that tire.
    Verify (possibly) by lifting that side of the car and grabbing the tire at 12 and 6 oclock and pivoting in and out. if you get any wiggling, you definitely have a wheel bearing issue, though a failing bearing CAN AND WILL fail without making noise OR allowing any play in the tire!
    Edit: check out the Duratec Maintenance forum, and read the "read me first" thread for a how-to on bearings, and a list of all possible repair options.
    .99 Silverfrost
    Call me for free, if you need any help or anything.
    |_|0|_|
    |_|_|0|
    |0|0|0|
    Sep 2002
    St. Louis, MO
    2,882
    right front wheel bearing is bad...
    Retired 98 Contour SE Sport 2.5 Duratec ATX - Dead transmission @ 235K miles
    2001 F250 Super Duty 6.8L 4x4 - The NEW Workhorse 152K.
    2007 Mariner 3.0L AWD - Wifey's new ride
    2000 Contour V6 ATX Acquired 11/1/2013
    What are the concequences of not getting this fixed ASAP? its a long weekend, and I have to work tuesday morning, so i'll need to put atleast 100 miles on it before i can get it in/get parts
    well, if your wheel bearing fails... your wheel could fall off
    My old pre98 I drove for about 2K miles on a bad wheel bearing. I didnt know it had a bad bearing until about a month after I bought it when I got my licence and started driving it more. If its not extremely loud, then you have a little bit of time yet, but thats something I would fix ASAP. Plus its a pretty easy DIY if you just buy a new hub with the new bearing inside.
    Autozone lists and Timken Assembly for $41 and you could probably replace it in a couple of hours.
    http://www.autozone.com/R,APP1137729...ductDetail.htm
    Sold the CSVT, replaced it with a Screaming Yellow 2003 EAP SVT Focus
    Mar 2007
    Livonia,MI
    65
    Dont buy autozone junk, its worth it to get oem on stuff like that Aftermarket is hit or miss, you could get one bearing thats better then oem but the next one in the batch could fail in 3 months, my recommendation is ford oem, if your anywhere near michigan call John @ Village Ford parts depot, tell him your problem and Ryan from Westland Car Care said he'd beable to hook u up @ a good cost.
    1999 Silver Frost SVT #998 of 2760 SOLD!
    1994 Pearl Yellow Stealth RT/TT
    May 2004
    Calgary, Alberta, Canada
    4,437
    You guys are forgetting that the bearing has to be pressed in with a 10 ton press.
    Send the knuckle to stazi and he will replace them with OEM new parts for 59 bucks.
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
    Jan 2006
    Chicago Area
    229
    You could use a 10 ton press to do the job. I have one and it didn't budge the bearing when I did mine. I choose to use a Dremel tool cut off wheel on the bearing race. I cut about 90% way through the race and it then poped out with a tap from a hammer & drift. This took 2-3 wheels and about 30 minutes. I did use my press to install the new bearing.
    I plan on doing the other bearing soon before it needs it. I have to do LCA's anyway (2 bolt) so I'll have things apart as it is.
    '00' SVT Contour
    '87' VW ITA 16V Scirocco race car
    "Drag racing is for those drivers who can't brake and downshift at the same time."
  9. #9
    Nov 2008
    Eau Claire, WI
    134
    Quote Originally Posted by willeh View Post
    Now, the sound is kind of a humm, and it gets pretty loud around 80 (50 mph) it goes with wheel speed, not engine speed (when i put the car in neutral and coast, it continues, and it just gets louder as i go faster)...
    I am having the exact same symptoms as this guy had. I replaced the right front wheel bearing and it didn't fix the problem. Is it possible that it is a transmission bearing or maybe a rear wheel bearing (Source of sound doesn't seem to be in the rear) is the source of the noise?
    At highway speed (55-65mph) I can get the hum/buzz to disappear completely on a long right veer in the road.
    any Ideas?
    97 Contour SE V6 MTX
    '98 Mystique LS ATX V6 165,000 miles-sold 3/2/10
    ...and the recent acquisition
    '97 Contour SE MTX V6 97,000 miles
  10. #10
    Jun 2000
    Staten Island NY USA
    7,520
    it's entirely possible you replaced the wrong bearing. remember, sounds travels.
    1999 Silver Frost SVT #609 of 2760
    SOLD! and now RIP
    2001 Z06 - Quicksilver Metallic - 406RWHP
    1995 Impala SS - Black - Bunch of Lingenfelter stuff
Page 1 of 2
1 2 LastLast
