The Ford service manuals have some SERIOUS issues in this section then. The purge valve looks completely different in the picture, and is in a different location.
The manual shows a cylindrical object inline with the fuel line that has nipples sticking from the sides 180 deg apart from each other. It shows it with a long pigtail (the connector in mine plugs directly into the valve). It says it is located on the passenger side shock tower and has a 3 pin connector instead of two. Also, mine appears to be bolted to the firewall, where the manual says there is no attaching hardware.
'98 Silverfrost SVT
'95 SE 2.5 ATX (wife's) - for sale
'05 Freestyle Limited AWD
'99 F250 Superduty 4x4 Supercab
'66 Mustang 289 4bbl 4spd
