Results 1 to 10 of 10
Thread: Plasma TV Question - Jerky Motion
    Aug 2002
    Memphis, TN
    1,531
    Default Plasma TV Question - Jerky Motion
    I just purchased a 42" Vizio plasma. I'm using an HDMI connection from my HD cable box. The picture quality is fantastic, but I've noticed that any type of slow camera movement (pans, zooms, etc) are extremely jerky. The issue is even more noticeable when watching a ticker tape or bottom line, as the scrolling text is ridiculously jittery. It looks like it's going to bounce off the screen! There's no blur...just a ton of vibration.
    So, is this occurrence being caused by:
    1. The nature of plasmas in general?
    2. The nature of this particular model?
    3. A bad TV, which needs to be returned?
    4. The HDMI connection? Should I try component?
    I'd really hate to return this TV because, like I said, the picture is great. But I just can't stand this much jerkiness...
    Chris G.
    ~ 98 Mystique LS ATX
    Jun 2004
    Plattsburgh, NY
    5,114
    I'd start with the connection... try component. My dad got a plasma, and hooked it up to HDMI for digital cable... the picture kept cutting in and out. After a couple days it stopped and never did it again.
    -Matt
    2010 Subaru Forester
    '99 Tropic Green LX, Zetec, ATX
    Oct 2005
    Toledo
    1,255
    Quote Originally Posted by Matt R View Post
    word i'd try something different to see if anything changes
    my plasma never does anything like that but im using component
    WRB Subaru BRZ Limited (current car)
    Black CSVT on FSVTs (SOLD)
    http://www.cardomain.com/ride/3933448/
    TRed CSVT on FSVTs (previous car)
    http://www.cardomain.com/ride/2154233
    May 2000
    Grand Rapids, MI
    26,530
    Blog Entries
    1
    I thought this post was going to be about pr0n on a big screen.
    Former owner of '98 SVT #1,173. Need a 95-00 Ford CD manual? PM me
    Sep 2004
    Kennedy, New York
    973
    is it like framerate lag? My 42" sanyo plasma does this sometimes while playing 360, I turn the tv off and turn it back on and all is good, It doesn't happen often, though
    98' Contour SVT #2037- 132k, (blk/mnb) 04' 3L ported w/ SVT cams
    01' Chevrolet Blazer- 115k, mostly stock
    Nov 2004
    Elmhurst, IL
    1,289
    It should not be the HDMI...it is a higher quality standard than component.
    However, do try another connection type just to see if it improves. Also look into the various settings on both your cable box and within the TV itself.
    I have a VIZIO LCD and was able to get a much nicer picture and smoother movement after adjusting various settings.
    If you still have issues post the specific model tv and cable box you are using and I might be able to help further.
    If component fixes the issue I would NOT be satisfied with that, you should be able to take full advantage of HDMI.
    -Adam-
    00 SF/MB CSVT #1464 - 2005 port-matched 3L - SOLD
    00 SF/MB CSVT #0939 - 2005 - GT3076R - 3.0T- SOLD
    Repairs / Installs? Yep, I do that.
    May 2000
    Flori-duh, well at least my vote counts here
    3,138
    Is this a problem on HD signals or SD signals? I'd try the different cables (component) to rule that out.
    It isn't an inherent problem with plasma TVs though, FWIW
    Jan 2006
    Montreal
    1,059
    What resolution are you watching in? I used to notice that sometimes on our tv on 1080i so I took that off. 720p is much better. The only thing that makes me think this isn't the problem is that you said its for slow moving things, whereas this i vs p deal is usually more noticeable for fast changes.
    00 Silver Frost SVTC #1429/2150: Born 10 Jan, 2000
    3.0L, Spec Stage 3 Clutch, LSD, Koni Sport Kit +more
  9. #9
    Apr 2008
    North Texas
    3,570
    It could also be a non HD channel coming from the HD box. On my LCD tv when I watch the HD channels they are crystal clear but some of the regular channels look awful and blurry.
    2000 "Amazon" Tropic Green CSVT #836/2150
  10. #10
    Aug 2002
    Memphis, TN
    1,531
    Turned out to be the HDMI. Plugged in component cables and bam, problem gone.
    FWIW, the problem was happening on both SD and HD channels.
    Chris G.
