Results 1 to 6 of 6
Thread: HOW TO eyelids on headlights
    Jun 2008
    Kansas City, MO (Liberty)
    33
    Default HOW TO eyelids on headlights
    I was wondering wear i could get some eyelids for the headlights on a csvt or if you could even paint them on PM me with responses
    1998 Black CSVT- Work in progress
    http://www.cardomain.com/ride/3240762/2
    Nov 2008
    Parris Island, SC
    1,918
    yeah... you can buy them. im not really sure where.
    i just rattle canned them on. if you look at the lens... there are horizontal lines going across it. there are either 4 or 5 i believe. take some of that blue painters tape along the bottom of the top line. then after you get that use news paper to cover the rest of the light or tape the whole thing. it really doesnt matter. i would use a spray gun if i did it again... but the rattle can worked just as well.
    before:
    After:
    the lines in the lens are easier to see in the second pic than the first... but it should give you an idea on how to do it.
    i found this pic of the lights actually taped up and all...
    Mike
    2003 Mazda Protege5
    Off to USMC Recruit Training. See you all in mid November.
  3. Default
    Quote Originally Posted by drev44 View Post
    I was wondering where i could get some eyelids for the headlights on a csvt or if you could even paint them on PM me with responses
    here is a link of a better way to do it then paint and it looks better and dont ruin your headlights
    http://contour.org/ceg-vb/showthread.php?t=17239
    I noticed that CRG painted on the outside of his lenses. Would it be possible to paint on the inside; for example: I'm going to be hightowering my lights, which requires the lense to come off. During that process, could I paint the inside along the line and up? Or will the heat of the light make it flake out and peel?
    1998 Blk CSVT #4754: '03 ported 3L, MSDS headers, Torsen Diff., Opt'd SVT TB
    2001 Burgandy Gran Prix: there when I need it
    2004 Blue Chevy Cavalier: Four pistons of Fury
    2005 Redline CTS-V: 400hp of awesomeness on the weekends
  5. Default
    You could try something like this.
    http://www.401graphics.com/headtailtint.htm
    Allows you to take off and change, unlike painting.
    Nov 2008
    Parris Island, SC
    1,918
    Quote Originally Posted by SVTRacer View Post
    It shouldn't flake and peel. Or so would the chrome housing you are painting anyways.
    But as SVTracer said, if you do that, its def more permanent. If you paint the outside of the lens, you can always sand it off and then put a clear coat on the lens and it would look like new again.
    It also might look goofy. You would see the clear lens then the eyelid. Then if your lights are or get hazed it might look real bad
    Mike
    2003 Mazda Protege5
Similar Threads
  1. Headlights with eyelids I made.
    By svttour2000_03 in forum Body/Suspension/Brakes
    Last Post: 02-10-2009, 08:28 AM
  2. 4 sets of Fiberglass Eyelids!
    By Top Shop in forum Group Buy
    Last Post: 07-01-2008, 01:11 AM
  3. like new headlights w/ silver cf eyelids
    By icysvt in forum Body/Suspension/Brakes
    Last Post: 12-21-2007, 12:23 AM
  4. Custom Projector Headlights....
    By Reebs in forum Body/Suspension/Brakes
    Last Post: 11-04-2007, 07:37 PM
  5. Carbon Fiber Shop
    By Top Shop in forum Exterior
    Last Post: 04-13-2007, 07:16 PM
