Results 1 to 2 of 2
Thread: ABS & TCS light on + grinding???
    Mar 2009
    Central VA
    140
    Default ABS & TCS light on + grinding???
    The other day i put my new fender on, put my new trunklid on and gave my SE a very good washing. Now sometimes after i wash it the ABS light comes on (very rarely) but goes out after a few miles of driving. But after i washed it yesterday i went to pull out of my driveway when i felt a strong growl and something stopped the car. I thought alright what did i run over? But got out to find nothing. I got back in the car and went to pull off again and the same thing happened plus the TC & ABS light started flashing back and forth. The ABS light would come on and the TC light would go out, then the TC light on , the ABS light off and so on... So after i few struggling pulls the car freed up and pulled off with both lights coming on all the way. Now i have these 2 lights on and dont know where to start looking for trouble areas.
    Now my wiring harness is rotted out but does not cause any driving issues since ive owned it. I have the new harness i just havnt put it on, because i dont want to tear it all down and something go wrong and i have no ride to work...
    Can anybody please help me??
    Mar 2002
    NJ
    942
    My 96 SE only has ABS, but from years 2000 till 2006 whenever I washed the car my ABS light in the dash came on till things dried up. I put off getting the wiring harness recall done till I was almost at the 10 year /100000 limit because the wire insulation wasn't really too bad. I did once in 2000 get a quote from Ford to fix the ABS. They said it needed a HCU (hydraulic control unit) and wiring harness, cost $2700.00. I said no thanks and lived with the intermittent light.
    When I finally had the 99M03 recall done in 2006 the ABS light hasn't come on since.
    I guess it didn't really need a new HCU did it FORD?
    Long story short, replace your harnesses, probably everything will work fine again.
Similar Threads
  1. ABS light flickering and car stalls with AC on
    By Irish Pride in forum General Troubleshooting
    Last Post: 06-23-2009, 09:12 AM
  2. ABS and brake light on
    By starjammir in forum General Troubleshooting
    Last Post: 12-26-2008, 11:34 AM
  3. Funny TCS and ABS light
    By 95_Mystique in forum General Troubleshooting
    Last Post: 12-17-2008, 10:29 PM
  4. ABS light ON and OFF
    By mandzo in forum General Troubleshooting
    Last Post: 08-12-2008, 04:50 AM
  5. Problems with light - Quite long!
    By TGO in forum Common Interests
    Last Post: 04-05-2007, 08:02 PM
