Alright, first off I'm doing the swap in a different car anyway.... but I wanted to ask if anyone's used a 99 3L from a Taurus/Sable and if they did, what did they have to modify besides the normal to get it working?
I understand I'll have to use an electric water pump. fine with me.
I like that these older ones are already split port so I can fit the SVT UIM on there with little to no modification. LOL I just like the way it looks. reminds me of the SHO.
I also just purchased an ECU from what I believe is a 98 CSVT with return style fuel setup.
I take it I can use the newer pistons and all that from the newer engines since it's still all the same size internally?
Also wondering if the Contour/Cougar MTX75 would still mate up to the older transaxle.
So here's the engine I'm looking at right now..... I know I SHOULD use a newer one, but for NOW I'm just trying to do it for the cheapest. I'll probably change engines eventually anyway, and the X type's trans.
Thanks!
