Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 21
Thread: NTK Oxygen Sensor
  1. Question NTK Oxygen Sensor
    I'm replacing my upper oxygen sensors.
    I purchased NTK 22060 sensors. However the connectors to the wiring harness are round instead of square.
    Would cutting the wires and attaching the old connection to the new sensors be a good idea?
    I'll take pics if need be. Thanks!
    (Apologies Mods I accidentally tried to post this in the HOTO section)
    Aug 2009
    Farmington Hills, MI and Big Rapids, MI
    234
    IIRC, you can't cut and attach O2 sensor wires because they carry air through them don't they?
    1998 Contour SVT #2407
    Black with Midnight Blue Interior
    Port-match 3L Swapped
    My Cardomain - My Probe and Acura were from when I was in high school...
    May 2009
    Melrose, MA
    800
    wires carrying air?
    Andrew
    T-red/MNB "The Wizard" 1998.5 CSVT #5314 111,400mi
  4. Default
    I'm pretty sure wires don't carry air
    After a little more reading I just decided to splice the wires.
    We'll see if it pays off shortly!
    Jun 2008
    okc, oklahoma
    846
    i think you got the wrong o2 sensor......theres a difference between upstream and downstream..... I'm not sure they'll work the same way......
  6. Default
    That would totally suck. I'll look at the downstream connectors.
  7. Question
    Yeap they gave me the downstream sensors... damn... just finished the one by the firewall...
    Can anyone confirm the technical difference between the upper and lower O2 sensors, is there a difference besides the plug itself?
    May 2006
    Plymouth,MI
    2,877
    Blog Entries
    1
    Quote Originally Posted by Brokendown View Post
    And your doing a 3L? Pwntbywombat#2
    '98.5 2.5L Mystique LS T-Red
    '98 SVT E0 BLK/MNB#1663 Port matched 3L
  9. Question
    Gonna bump this and hope for a quick reply.
    Besides the connection is there any difference between an upstream and downstream o2 sensor?
  10. #10
    Jul 2005
    South Jersey
    520
    Old 02 sensors used to be vented through the wire harness. Crazy but true. This should not be an issue anymore. Splicing is fine but solder, don't crimp. You're dealing with very low voltages (0.1-0.9 Volts). Crimped connections can have enough resistance to cause problems at such a low voltage.
Similar Threads
  1. duratek, 1995, lacks power
    By peecoman in forum General Troubleshooting
    Last Post: 08-10-2008, 04:07 AM
  2. a little help
    By Redeemer in forum General Troubleshooting
    Last Post: 06-06-2008, 12:36 PM
  3. Cleaning your MAF
    By BigheadVelaSVT in forum Duratec Maintenance
    Last Post: 07-19-2007, 11:35 PM
  4. wideband
    By posthuman63t in forum Duratec Performance
    Last Post: 10-06-2006, 08:18 AM
