Page 1 of 6
1 2 3 ... LastLast
Results 1 to 10 of 52
Thread: Coil on plug question
    Default Coil on plug question
    I'm doing a hybrid swap and would like to use the COP off my 06 escape 3L first can anyone post up a wiring diagram? Or does anyone make a plug and play harness?
    Second will the coil on plug system mount/seat properly with the stock SVT 2.5L valve covers?
    Dec 2001
    Gales Ferry, CT
    24,946
    Blog Entries
    93
    if you search around you will find a wiring diagram that was posted.
    and no the cop will not mount to the stock 2.5L valve covers. if you want to use COP with the stock intake you need valve covers from a 01 3L. the later valve cover will not clear the stock intake.
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 99 Contour SE Sport <- traded in 2/13
    - 2k Contour SVT - #2137
    Cool thanks for the info. I tried searching but it wasn't cooperating typed in "coil on plug diagram" I'll try again with some different keywords.
    Dec 2001
    Gales Ferry, CT
    24,946
    Blog Entries
    93
    Quote Originally Posted by Cody4130 View Post
    search = cop
    http://www.contour.org/ceg-vb/showth...&highlight=cop
    - 12 Focus SE
    That's what I was looking for thanks!
    So is the consensus this is basically an aesthetic mod with a chance of higher rpm misfire and interferance and COP in our application produces less spark energy than the stock coil and wires?
    Double post... Stupid iPhone
    Mar 2004
    Louisivlle Ky
    6,976
    I dont like that wiring diagram for the COP setup. the OP states that our coil packs have 6 coils in them and that the pairs are wired in series. this is not correct. there is actually only 3 coils, and each coil fires 2 cylinders. as such, they are not series or parallel, just 3 separate coils.
    this website shows a good picture of how the Ford coil pack is designed and its basic wiring.
    http://rockledge.home.comcast.net/~r...y/DIS_EDIS.htm
    ill include the picture separately but you should read through the site.
    TZT Performance http://www.tztperformance.com/
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
    Feb 2006
    Southeast Michigan
    2,368
    I'm against COP in 3L Contours. I'd love for someone to debate me.
    98.5 T Red SVT #4636/6535 ... SVT cam'd 3L Turbo
    Owned 28 SVT's, looking for my 29th. Need SVT Parts? PM me!
    PM me for engine/trans/suspension swaps, etc... 3 Liter Swaps done RIGHT!
  9. #9
    Sep 2007
    Pittsburgh area, PA
    1,245
    Quote Originally Posted by Reebs View Post
    Don't want to debate, just wonder why you think that way?
    I haven't looked into it much myself.
    -J
    '99 SVT Silver
    Clean DD
    '91 LX Bimini Blue
    427"/88mm @ 16psi....yeah 4 digit power
  10. #10
    yeah i guess ford got it wrong when they put them on there from the factory. my bad jsut seen you said on contours. But either way I havent seen a difference in mine
Page 1 of 6
1 2 3 ... LastLast
Similar Threads
  1. Plug wire question
    By wht02lightning in forum General Troubleshooting
    Last Post: 03-29-2009, 11:58 AM
  2. 99 Grand Marquis Spark Plug Removal (Coil on Plug)
    By mcgarvey in forum Common Interests
    Last Post: 10-30-2007, 01:51 PM
  3. Replies: 25
    Last Post: 10-01-2007, 11:37 PM
  4. hesitation/bucking is back
    By getsum111 in forum General Troubleshooting
    Last Post: 06-21-2007, 03:46 PM
  5. Coil Pack Question
    By iBrent in forum Duratec Maintenance
    Last Post: 06-10-2007, 08:01 PM
