Results 1 to 7 of 7
Thread: Engine Removal Mega Wires!
    Oct 2006
    Up North New Jersey
    1,862
    Red face Engine Removal Mega Wires!
    Hey Guys, So my engine is half way out hanging high but still in my engine bay!
    There are a huge group of wires by the mega fuse and such that seem to be either caught on the engine or stuck to it. I did not remove any of these. Please let me know if I just need to push them away from the engine or do I have to do something else.
    Looking from the front of the car it is on the passenger side/rear of the engine bay on the side and behind the engine.
    For Reference(they are running on the firewall):
    Thanks CEG
    - amyn
    99 (No Paint, No Powertrain, No Doors, No Trunk) CSVT - 0532
    Koni/GC's - 18" @ 15.2lbs - BAT 21mm RSB(Reinforced) - OMP/Rawburt STB - MSDS Headers to Bassani Catback - Ford Racing Wires - CF Trunk - Parkedcar Stamped - Samco Hosed - Baer BBK - 3L Turbo
    May 2006
    Plymouth,MI
    2,959
    Blog Entries
    1
    They can stay with the engine when you pull it.
    It's probably just fighting you, just keep rocking it back and forth.
    Edit: is your AC compressor off? Belt still looks under tension.
    '98.5 2.5L Mystique LS T-Red
    '98 SVT E0 BLK/MNB#1663 Port matched 3L
    Oct 2006
    Up North New Jersey
    1,862
    The AC Compressor is on.... But I removed the Condensor(radiator type?) and the connections to it.
    I am almost sure I will be removing all the lines and such involving the AC so I didnt care to open it.
    - amyn
    To get that wire pack out with the engine you need to disconnect it from the computer on the passenger firewall under the power steering tank and from the connection right in front of the brake master cylinder.
    Oct 2006
    Up North New Jersey
    1,862
    I took the two bolts off (8mm) that bolted it onto the rear valve cover. I did not want to take it off at the time. I will take pictures now and from there I will remove them to help me with reinstalling!
    - amyn
    Feb 2006
    Southeast Michigan
    3,001
    Looks like you still didn't disconnect the harness from the PCM under the power steering res as Bugzuki was saying. You at least still have that part of the harness clipped on the firewall as I can see in the picture. Pull the harness out of that, but first, you will need to pull up the powersteering res and use a 10mm socket to disconnect the PCM, Similar to the main harness on the drivers side (by the Brake fluid Res). You will also need to remove the ground wires for the PCM. Also a 10mm. That part of the harness comes out with the motor. And if your A/C compressor is still on, you will need to remove that (Three 10mm bolts), after pulling the serpentine belt off. That can rest on the subframe. I think you mentioned removing the A/C Condensor (not sure why?), but you will need to remove the compressor from the motor.
    98.5 T Red SVT #4636/6535 ... SVT cam'd 3L Turbo
    Owned 28 SVT's, looking for my 29th. Need SVT Parts? PM me!
    PM me for engine/trans/suspension swaps, etc... 3 Liter Swaps done RIGHT!
    Oct 2006
    Up North New Jersey
    1,862
    Thanks Reebs. I think Im good. I understand 100% what you are talking about. The Compressor wasnt taken off casue I didnt feel like taking it off. I will take it off as soon as I get the engine on a stand and start cleaning my engine for reinstalling.
    - amyn
Similar Threads
  1. Plugs left beside the engine
    By khhess in forum General Troubleshooting
    Last Post: 06-29-2008, 10:46 PM
  2. 144k and a heavy vibration upon acceleration and under power
    By Thresher in forum General Troubleshooting
    Last Post: 12-10-2007, 11:29 AM
  3. Replacing Oil Pan
    By Myrosia in forum General Troubleshooting
    Last Post: 09-25-2007, 01:02 AM
  4. URGENT: Engine Removal ??
    By BillC in forum Zetec Maintenance
    Last Post: 10-19-2006, 11:39 PM
