Results 1 to 10 of 10
Thread: Just got a 1998 Contour Zetec for $360
  1. Default Just got a 1998 Contour Zetec for $360
    It has a transmission issue. I pulled a P0372 code from it with my Xcal2. I use the Xcal2 on my turbo ZX2. Anyway, I've read some confliting info about this code and thought that if I posted up specific problems, I might get a more pinpointed reply. I'll be sure to post that in the right section. I also tried to put a how-to in your forum, but I guess mods have to move it there. I wrote this how-to for the ZX2 but the VCT equipped Contour/Mystique will be the same.
    IMPORTANT The ZX2 Zetec is a non-interference engine. This means the valves are not capable of touching the pistons at any time. If your belt breaks, there will not be any valve damage. There are reliefs cut into the top of the pistons that allow clearance for the valves if the belt breaks. Most engines are interference and will cause several hundred or even thousands of dollars of damage when a timing belt breaks. Most shop manuals list the ZX2 as interference but it is not. Many people seek out this how-to because a mechanic has informed them that they have valve damage and quoted a repair price over $1000.
    This can be done by people that can change their own oil. But, if you have any doubts about yourself then it would help to have someone more experienced then you to help. The average you can save doing this yourself, $250-350.
    Note: if you have issues with the timing belt walking off the gears, then you may have a worn or tapered lower timing gear. The early engines had a two-piece design that was prone to this type of failure. You can update it to the later one-piece model. The part numbers for all the pulleys are listed at the end of this how-to.
    I do offer a video how-to of this procedure for $14.50 shipped in the US. I will ship to Canada for an additional price. I'll have to find out from the Post Office about the extra cost. The disc also includes timing kit (the pulleys) install, VCT gear delete, and front oil seal replacement. There is a review written of this video on the bottom of the 2nd page.
    Tools:
    A. Cam lock tool. Can be made from flat-bar stock (9" long, 3/4" wide, and 3/16" thick) or bought at some part stores. www.zxtuner.com carries it.
    B. Metric socket set and box end wrench set. You will only need the 8 mm, 10mm, and whatever size the crank pulley bolt is, I think that is 19 mm.
    C. Jack and jack stand of course.
    D. Lug nut wrench or equivalent socket to remove the wheel.
    E. Large adjustable wrench.
    F. Set of allen wrenches.
    G. Haynes or similar manual for torque values.
    Getting started:
    1. Put the passenger side of the car on a jack stand and remove that wheel. Remove the plastic splash guard that covers the bottom of the car and the passenger side. These are 10 mm bolts.
    2. Remove the serpentine belt. The serpentine tensioner is just above and to the left of the a/c compressor. The bolt on it is 13mm. Use a breaker bar like in the picture above to rotate the tensioner clockwise. The tensioner is spring loaded and will return to its' original position when you let go of it. For this reason, I recommend you leave the breaker bar or wrench on it so you don't have to worry about getting it back on there when you go to put the belt on. Now you remove the crank pulley. This can be done without an impact gun. Use an impact gun if you have one, but if you don't, then follow this procedure. Use the correct socket for the crank bolt (I think it is 18 mm) with an extension and breaker bar. Put the breaker bar and socket on the bolt and brace the breaker bar against the lower control arm. I used another jack stand and a few small boxes. The idea is to have the bar snugly pressed against the control arm and propped up from underneath so it sits square with the crank bolt. Now, dis-connect the 3-wire connector at the ignition coil so the car won't actually start. Make sure the car is not in gear and no one is standing near the breaker bar. Bump the key about a second in the start position. This should break the bolt loose and now you can go remove it.
    3. With the crank pulley off you can now see the timing belt gear. Remove the splash shied cover that is behind the crank pulley. It is held by two 8 mm bolts I believe. Also remove the upper timing belt dust cover. These are 8 mm as well.
    4. Remove the valve cover. Start by dis-connecting the VCT connector on top and remove the spark plug galley cover if you have one. These are 8 mm bolts. The valve cover is held on by 8 mm bolts as well. The one on the passenger-firewall side has a stud on it and will require the use of an 8 mm wrench or deep well socket. Do not let the gasket touch the ground. Soak the gasket in WD-40 so it will swell back to original shape and you can reuse it.
    5. Now we set the cams at TDC. TDC is Top-Dead-Center. It is the higest point in the cylinder that the #1 piston reaches on the compression stroke. If you have the cam locking tool, it will only slide into the back of the cams (driver side) when they are set at TDC. You may have to rotate the exhaust cam several degrees to get the cam locking tool to slide into the exhaust cam. This is normal because of the nature of the VCT. If you need to rotate the cams to get the locking tool in, then put the crank bolt back in the hole and turn the entire crank with that bolt. After the locking tool is able to fit into the intake cam (firewall side) then use a large adjustable wrench (or 15/16" open-end) on the exhaust cam (there are flat spots near the belt for the wrench to fit onto) to rotate the exhaust cam.
    If you are replacing a broken belt or a belt that has otherwise skipped time, then you will have to set the cams at TDC and the crank at TDC separately. If this is the case, then follow the instructions outlined in the blue text. If you do not have a broken belt (you are replacing a belt before it breaks or otherwise fails) then you do not have to set the crank at TDC, it will be set when you set the cams at TDC
    5a. If you need to set the crank at TDC separate from the cams then you can do so with a couple of methods. You can remove the spark plug from the #1 cylinder and insert and long screwdriver into the hole. Then you rotate the crank until the screwdriver is at its' highest point. There will be a point where you can move the crank just slightly and the screwdriver will not go up or down. This is TDC for the crank. One final method that has worked for me is to just set the crank key (the small notch the crank pulley slides over) at the 12 o'clock position. Notice that the engine leans slighty forward. Set it at 12 o'clock in relation to the engines lean. It'll look like 12:10 to you. Since each tooth on the crank pulley is about 16* of timing, it would be hard to be off a tooth and not notice.
    6. Now with everything set at TDC you can remove the old belt. If the belt has already removed itself (broken) then you still have to loosen the tensioner. Below the intake cam gear you will find the tensioner. It has a small notch on the front with a place to put an allen wrench and a 10 mm bolt sticking out. You have to loosen the 10 mm bolt. It is a small space and this is where a long 10 mm box-end wrench comes in handy. Loosen it about 3 turns and push that allen slot down (it rotates) and this will release tension from the belt. Slide the belt off. To make belt install even easier, loosen the bolt enough to pull the tab out of the back plate. This will give you more slack to work with.
    If you have a pre-99.5 with a two piece crank gear, replace this gear with the single piece gear. Part number is at the end of this how-to.
    6a. Ford put a TSB that fixed some of the issues with the new belt walking off of the cam gears. The problem is that the new belt would bunch up between the gears a bit when the springs loaded the cams and the VCT was being actuated. The fix is to set the cam gears neutral to the new belt. You'll want to remove the cam locking tool to prevent breaking the back of the cams out. Use a large wrench to hold the intake cam in place while you use a Torx bit (T55 I think) to loosen the intake cam bolt. You only need to loosen it enough so that you can move the cam gear free of the cam. Now, use the wrech and the same bit to remove the oil plug from the VCT hub. Put some rags below the hub to catch the bit of oil that will come out. Now, the exhaust bolt can be seen inside the hub. It is an 'E' (inverse torx) bit. I've always just used a 12-point 16mm socket. Loosen the exhaust cam bolt enough to move the VCT hub (exhaust cam gear) free of the cam. Put the lock tool back into the cams and continue with the next step.
    7. Now we install the new belt. This can be a bit difficult because the new belt is not stretched at all and will prove difficult. You may be tempted to try prying it on with a pry bar (or screwdriver), please resist the urge to do that. After you cuss a lot and the belt slides on make sure it sits just inside the gears the entire length of the belt. Now you can apply tension. Slide the tab into the back plate. Tighten the tensioner 10 mm bolt up just a enough to keep the allen key from falling down under its' own weight. Behind the tensioner is a back plate with a notch cut into it. You can see there is a line it is supposed to point to. Make sure it is pointing to it when you start to put tension on the belt by rotating the allen slot counter-clockwise. Now you need to hold that allen slot with the allen wrench in a 3 o'clock position while you tighten the tension bolt. It is a very small space to work in and it will make you mad, but it has to be done. Get the bolt good and snug, 18 ft-lbs. Don't over tighten it, it might break off.
    7a. Now that the belt is installed, you have to tighten up the cams gears. Starting with the exhaust cam gear, use a wrech to hold the cam still (leave the lock tool in, but hold the cam in place so you don't break the slots out) and tighten the bolt up to 30 ft-lbs. Now, hold the intake cam still and tighten the bolt up to 50 ft-lbs. Remove the lock tool and tighten the exhaust cam bolt up to 80 ft-lbs. Install the oil plug into the VCT hub and tighten it up to about 15-20 ft-lbs. All of this sets the cam gears to neutral and prevents the belt from bunching up in the center during VCT operation.
    8. Now you can put it back together. If you haven't already, remove the cam locking tool. Rotate the crank with the crank bolt one full turn to make sure the belt isn't going to bind on anything. If all is well then you put everything together the way it was removed with the following notes:
    A. Re-connect your coil plug if you removed it, some people forget then get scared when the car doesn't start.
    B. When you install the valve cover, you need to wipe the head mating surface down to make sure it is clean. Here is the torque pattern and sequence.
    Thanks to ZZZX2 for that picture.
    C. This would be a great time to install a UDP
    D. When you install the crank pulley, use some medium strength Loc-tite on the bolt to ensure it won't come off. Just get it as tight as you can. The engine will move but that is fine. The Loc-tite will keep it from coming back out.
    Torque Values & Part Numbers:
    Torque Specs
    Idler pulleys: 35 ft-lbs
    Tension pulley: 18 ft-lbs
    Part Numbers for pulleys:
    Timing Belt Tensioner
    F8CZ-6K254-AA
    Pulley (later model, 99.5+)
    I need this number, Ford doesn't give them out, just read it off the bag.
    Pulley (Upper Timing Belt Pulley Pre 99.5)
    F8CZ-6M250-AA
    Pulley (Lower Timing Belt Pulley)
    XS4Z-6M250-BA
    Timing Belt
    F8CZ-6268-AA
    Crank Gear (single piece)
    F5RZ-6306-AB
    There is a part from Ace hardware that can be used as a lock tool. You can used the UPC code to find the part at your local store.
    Thanks to jrqf
    I did this from memory, so if you find that I missed anything, please let me know so I can correct it. As always, if you feel grateful enough to pay, my Pay Pal Addy is: bak_6965@yahoo.com
    -Another quality how-to brought to you by ZX2Fast.
    Brad K.
    Mar 2004
    Louisivlle Ky
    5,892
    welcome, while we already have a 98+ (VCT Zetec) timing belt FAQ in the Zetec section, its nice to have some pictures to go with it.
    also, for anyone else that may see this, the timing belt setup from pre98 Contour (non-VCT Zetec) to 98+ is different. of course they are both non-interference engines so, like you stated, there is no risk of damage to either the valves or pistons.
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
  3. Default
    I read that FAQ and it was very vauge. For instance, it said set the engine to TDC but gave no instruction on how to do it.
    Mar 2004
    Louisivlle Ky
    5,892
    Quote Originally Posted by ZX2Fast View Post
    yeah, it used to have pictures but they have since disappeared. the easiest way to find TDC though is to use the crank pin.
  5. Default
    I found the TDC pegs vary in length and do not always correctly set the crank at TDC. Using a screwdriver will always work and be accurate.
    Mar 2007
    Sunderland, MA
    5,762
    Blog Entries
    7
    Not sure about the VCT Zetecs, but on the pre98 (well, mine at least), if you put the crank pulley back on, there is a small notch in the crank pulley that you can line up with a notch on the oil pan for TDC as well.
    Ian
    Mine - CDW-27 Zetec ATX | Hers - D186 Vulcan ATX
    Aircougar Performance
    AWESOME! i wish i could have had this months ago when i had reset my timing. very east to understand with good pictures.
    Green on Black '93 SHO 3.0 MTX *SOLD*
    T Red '98 Contour SE (Zetec)
  8. Default
    Thanks, now if we can just get someone to move it to the how-to section.
  9. Default cam alignment bar
    I asked this in another post but its probably more appropriate here. This tool has reliefs in it for the alignment slots on the driver side end of the cams. As you know if the cams are upside down the file won't go in, but was wondering since this has reliefs if they are supposed to be aligned that way.
    http://massivespeedsystem.com/_massi.../i-273565.aspx
    I have watched a video on youtube where a guy by the name of Briansmobile1 that says to align them with the slot below the valve cover surface with his homemade offset tool but he goes on to say that is will work either way.
    I am interested in doing it right and not repeating it again so do you have any advice whether the slot should be able to use a file or if this offset tool is necessary?
    http://www.youtube.com/watch?v=FZFfi44tNA0
    Here's another interesting read but he doesn't mention how they should be oriented either:
    http://www.youtube.com/watch?v=fAnU58OgUYo
    What say you?
  10. Default
    This virus I have must have been affecting my brain last night. The crank turns twice as much as the cams so:
    crank (2 turns) : cams (1 turn)
    crank 720 deg : cams 360 deg
    crank 360 deg : cams 180 deg
    So it doesn't matter if the slots are above or below the flat gasket surface just as long as they line up! Use a cheap file or something similar to align. he expensive tool with the reliefs is not necessary. The crank will be in the same place (tdc) either on stroke 1 or stroke 3 depending on if the cams are up or down...
Similar Threads
  1. 1998 SVT Ford Contour #3310 - $3200
    By todras in forum Vehicles
    Last Post: 05-11-2009, 08:33 PM
  2. 1998 SVT Contour Rims
    By will1258 in forum Wheels and Tires
    Last Post: 05-16-2008, 09:35 PM
  3. New 1998 Contour SVT Owner!!
    By will1258 in forum New Member Classroom
    Last Post: 05-06-2008, 06:47 PM
  4. 1998 Ford Contour SVT for sale $1000
    By Black93fiveO in forum California
    Last Post: 08-16-2007, 11:17 AM
  5. 1998 Contour Improvements
    By trailtwister in forum General Discussions
    Last Post: 04-24-2007, 07:29 PM
