Page 1 of 7
1 2 3 ... LastLast
Results 1 to 10 of 61
Thread: Post Model, year, engine, pcm code
    Aug 2001
    USMA, West Point, NY
    7,002
    Default Post Model, year, engine, pcm code
    I think there is a need to figure out all the different codes used on our cars for reference purposes. Sometimes a straight 3L swap or maybe a swapped computer would require knowing what the codes are and the compatibility. We can sticky this list too. We can then start posting timing charts for various cam types as a list so that people can come on for a ready reference. So that means we want Contour/Cougar/Mystique/Sable/Taurus/Escape right off the bat.
    I'll start with what I know and you guys fill in the rest.
    Model/Year/Engine/PCM Code/INJ size/(Return,Returnless)
    Contour (4 Cyl)/????/2.0L Zetec/????/???/????
    Contour (nonSVT)/????/2.5L/?????/17#/Return
    Contour (nonSVT)/????/2.5L/?????/17#/Returnless
    CSVT E0/1998/2.5L HO/SFG0/19#/Return
    CSVT E1/1998/2.5L HO/????/19#/Return
    CSVT early/1999/2.5L HO/SFG2/19#/Return
    CSVT/2000/2.5L HO/XGT1/19#/Returnless
    Cougar/1999/2.5L/TRW3/17#/Returnless
    Cougar/2000/2.5L/TRW7/17#/Returnless
    My project website
    Oct 2003
    south carolina
    795
    Quote Originally Posted by warmonger View Post
    Cougar/1999/2.5L/SSD3/17#/Return
    1999 Cougar V6 MTX
    SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
    Nov 2003
    Plainville, CT
    8,140
    I believe all 98-98.5 SVT's use RJL1, not SFG0. Isn't SFG0 99?
    1998 SVT Contour 3L (B/MNB) #542 (His)
    2000 SVT Contour (SF/MNB) #1533 (Hers)
    2003 BMW 540i M-Sport (6 spd)
    2002 Cougar XR - XR Racing Red
    2002 Lexus IS300 SOLD!!
    Aug 2001
    7,002
    Lets see if this is closer. If you guys need to add to the list, just quote the latest list made, remove the quotes, and put in what you need.
    CSVT E0/1998/2.5L HO/RJL1/19#/Return
    CSVT E1/1998/2.5L HO/SFG0/19#/Return
    CSVT late/1999/2.5L HO/????/19#/Returnless
    Cougar/1999 early?/2.5L/SSD3/17#/Return
    My project website
    Feb 2004
    Somewhere in MO. Bleeding Mercon 5
    1,033
    Quote Originally Posted by CSVT1214 View Post
    This is correct. However, I'm not sure if the code changes over with the build date of the 98.5's, or slightly thereafter.
    Nissan North America (K.C. MO)
    Yes I have driven the GT-R. Yes, more than once...
    E0 3l--13's **Now A Campbells Soup Can**
    2000 SEVT-- The Pretty Car (Almost Done!!!)
    Apr 2004
    Dearborn, mi
    1,504
    cool, so now i know what my pcm code in the cougar is, i can confirm the returnless fuel system and 17 pound injectors though.
    Aug 2001
    7,002
    This list is obviously in the construction stage and contains inaccuracies so don't take it for gospel.
    As people see this thread an know what pcm code they have then they can edit it until we get a good idea about it.
    I'm positive I have tuned an SFG0 that was a 98 model. I also know that my 1999 model #222 was extremely early in the year as I took delivery on Oct 31, 1998 and my pcm code was SFG2. I can't see them changing from SFG0 to SFG1 and then SFG2 in just two hundred cars.
    I'm suspecting taht SFG0 was a 1998 code from mid model year or at least when the E1 version came out. The 1998 model year ran from May of 1997 through Aug or Sep 1998. It probably has all kind of baztardized combinations in the '98 E0/E1 run.
    Anyway, I haven't seen this information anywhere else so we may as well try to tally it up.
    I also want to incorporate Taurus/Sable and Escape vehicles so if ANYONE owns one can you at least input the Model, year, engine, and pcm code.
    My project website
    Aug 2001
    7,002
    Taurus/2003/3.0L/RXR1/???/????
    My project website
  9. #9
    Dec 2001
    Gales Ferry, CT
    24,931
    Blog Entries
    93
    i think that a xgt1 is a 2k svt pcm code but I am not possitive ...
    also it is my understanding the SFG0, 1, and 2 are for the 98.5 to 99 SVT ... I will get my 99 SE code when i get back home this weekend ...
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 99 Contour SE Sport <- traded in 2/13
    - 2k Contour SVT - #2137
  10. #10
    Oct 2003
    south carolina
    795
    Cougar/1999 EARLY/2.5L/SSD3/17#/Return
    YES IT WAS EARLY...12/98
    1999 Cougar V6 MTX
Page 1 of 7
1 2 3 ... LastLast
