Page 1 of 2
1 2 LastLast
Results 1 to 10 of 14
Thread: 1996 contour over heating problems
    Default 1996 contour over heating problems
    Our 1996 ford contour 4 cylinder, has problems, when its idiling, the car wont heat up, blows cold air, but when you drive, it starts over heating, i have changed top radiator hose, back radiator hose an thermostatt, am wandering if the water pump needs changed? i dont think its blowing blue smoke out teh back, and the water pump pulley seems to be makin some noise, need help fast pls, my email is eucredawwg@yahoo.com
    I seem to be in the same boat as you. I seem to be a little further in my troubleshooting though. I have a 1995 Contour V6 5speed that I bought at an auction on Sat. Temp was going straight to red when u turned the key on before even starting the car. Replaced the temp sensor and it fixed that problem. Gadge reads correct now. Start the car and rev it at 1500 rmps for about 5 min and the temp is to the "L" in normal. The fan kicks in right when it hits the "M" everytime. I also replaced the overflow cap. While the old one was holding, I questioned how much pressure it was holding after reading other peoples posts. I also have the problem with it getting really hot with no heat coming out the vents. No heat would lead me to believe that it is a heater core but the over heating almost sounds like the water pump. I have done a flush with prestone flush kit and a flush with viniger. Neither seemed to help at all. I am working my way up the value in the parts list. Starting with the cheapest and working twords most expensive. t-stat and gasket $12, temp sensor $26, overflow cap $8. I am going after the waterpump tonight because it seems to be alot less labor intensive than the heatercore. Please anyone if you feel I am wrong stop me before I do this! Priced the water pump w/ gasket and belt just under $50.
    Dec 2003
    Bildoland
    4,827
    The original water pumps in these cars usually blow up around 50k miles [the impeller breaks into pieces]. Replacing it is an easy job but the fact neither of you mentioned any overflow spewing into the engine bay makes me think it's another problem, especially if the temp guage is reading that high.
    4x4 5spd. Get some!
    Apr 2009
    attica, mi. right outside of lil mexico...imlay city if you havnt been on I-69 and seen the graffiti
    59
    try disconnecting the lines which run into the heater core at the firewall, and hook up a garden hose, and flush the actual core. i had an s10 which was overheating and had no heat... after flushing the sediment and garbage out of the core the truck ran cooler because water was able to flow thru the whole system as opposed to just the engine/radiator and with all the bypass hoses and garbage it wasnt cooling efficently with the plug in the system??? just a thought for ya
    97 Toyota Tacoma~Bagged and a 3.5" body drop.. lays rocker on the ground
    96 Buick lesabre Custom~2.5" Big Boi lift and 22's
    96 Ford Contour s.e.~Winter Beater, sounds like a racecar!
    Do you have a pic of where these lines are located to flush out the heater core? From other posts that I am reading it seem to be common that the temp guadge goes to 'L' in normal after replacing the temp sensor. To me that seems high but they say that is still and acceptable operating range. As for no heat that could be caused by a blend door malfunction? I really would like a digital readout of the acual temp the car is running at. It seems hot to me. The electric fan goes on when the needle hits 'M' and never goes off till u turn off the car. I know the t-stat is working. Nothing is blowing out the overflow.
    Quote Originally Posted by Pre98 View Post
    Yes, so true. My wife's original water pump lasted about 90k, but the replacement only lasted about 50k miles. Hot coolant and a plastic impeller do not go well together.
    '00 'Tour Zetec
    South Jersey
    http://www.cardomain.com/ride/2679238
    How many quarts does the cooling system hold? When flushing out the system all three times it took less than a gallon? If you were to hook a garden hose to the car to back flush the system, what hose would you connect it to? I have a feeling that I might have some air pockets in the system, I hear a gurgling noise from the t-stat area when I turn the car off. Frosty said that he hears this too once in awhile on his car, but not for a prolonged period of time. Mine isnt for a long time either.
    Jul 2008
    Juneau, AK
    1,007
    Quote Originally Posted by Rich2279 View Post
    Is this info for the Duratec or the Zetec?
    1998 Contour GL 2.0L Daily Driver
    1998 Contour SE 2.0L Gave to daughter.
    Pain heals, chicks dig scars, glory...lasts forever....
  9. #9
    Quote Originally Posted by Buehlz View Post
    I would connect the garden hose to the 1" hose coming from the coolant res and un clamp and remove the upper rad hose and let it rip. Oh and I would remove the stat also for the flush.
  10. #10
    Dec 2003
    Bildoland
    4,827
    Quote Originally Posted by Scorpion8 View Post
    Duratec. Someone chime in about the zetec wp? I couldn't tell you if they held up better or not.
    4x4 5spd. Get some!
Page 1 of 2
1 2 LastLast
Similar Threads
  1. 1996 SVT Contour?
    By Toddio in forum New Member Classroom
    Last Post: 05-21-2008, 10:29 PM
  2. Heating problems
    By morpho18 in forum General Troubleshooting
    Last Post: 01-07-2008, 11:02 AM
  3. 1996 contour problems
    By bedinabox in forum General Troubleshooting
    Last Post: 10-24-2007, 09:42 PM
