Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 23
Thread: Installed an oil separator in the PCV line.
    Nov 2006
    Colorado
    590
    Default Installed an oil separator in the PCV line.
    I recently did the Contour's every 20,000 miles clean the goop from the back of the throttle plate, as it causes it to stick closed. Decided to try an oil separator in the PCV line.
    Used a Parker 10F11E miniature oil coalescing filter and a couple of 90 barb fittings.
    http://pdf.directindustry.com/pdf/pa...67944-_48.html
    Spliced it into the PCV line between the PCV valve and the port on the bottom of the intake, right under the throttle body. I figure this will stem at least 99% of the PCV goop transfer, as this is the path the PCV flow takes when the intake is under vacuum. The PCV path is a bit different when the engine is at WOT, but even as much as I enjoy this car, I doubt I'm at WOT even 1% of the time.
    PCV plumbing before.
    PCV plumbing after.
    Parker oil separator on cowl, driver's side.
    In 3 days of the daily commute, it's already collected a small amount of oil. Now I wish I'd installed it 98,000 miles ago, I pulled off and UIM and the whole interior is just coated with a black, sticky tar-sh*t. The LIM is also a big sticky mess. I'm going to buy an upper and lower gasket set, rip the whole mess off and dump it in the parts washer for awhile. Will pick up some valve cover gaskets and replace those as well to stem some niggling oil leaks.
    Now that I have the oil trap, and once I have the intake mess cleaned up, I guess I'll discover how much the EGR contributes to crapping up the intake.
    Gary M.
    1985 SVO Mustang (turbocharged track whore), 1989 Taurus SHO (supercharged track whore), 1999 SVT Contour (Sedanus-Grocerygetter-Rapidus), 2008 Mercury Milan Premier.
    May 2006
    Plymouth,MI
    3,511
    Did that hose you used collapse on you yet?
    You have reached your stored private message quota and cannot send any further messages until space has been created.
    '98 SVT E0 BLK/MNB#1663 3L Always broke.
    '99 SVT E1 BLK/TAN#0741 Sold
    '07 MAZDASPEED3 GT
    Nov 2006
    Colorado
    590
    SAE 30R7 is Nitrile-lined with two spiral Polyester yarn reinforcement layers, it's rated to 50psi and 24" Hg vacuum for low pressure fuel and vapor emission use. Even when the engine is running at idle (high vacuum) if I crush the hose with my fingers, it returns to shape, so, no problems yet.
    May 2006
    Plymouth,MI
    3,511
    After a few weeks and lots of heat cycles my hose is mush Where did you get that specific hose?
    '07 MAZDASPEED3 GT
    Nov 2006
    Colorado
    590
    I bought a 25' roll of it long ago, may have been NAPA. Most good auto parts stores should have an SAE 30R7 fuel hose. 30R7 is not rated for fuel injection systems, it's for carbureted fuel systems, so it can handle some suction between a fuel tank and an engine mounted fuel pump.
    Parker-Hannifin has a fuel line/emission 30R7 hose, is there a Parker fitting store nearby you?
    http://www.parker.com/portal/site/PA...onlyid=N&from=
    May 2006
    Plymouth,MI
    3,511
    Probably, but i just needed it temporary. i'm redoing my pcv system, eventually.
    '07 MAZDASPEED3 GT
    Apr 2004
    Dearborn, mi
    1,490
    i need to do this too, but way more so my front breather, its always got a fresh run everytime i drive it...looks good mayne!
    Apr 2008
    North Texas
    3,550
    I had two installed and the front breather trap never had a single drop of oil in a year so I removed it. The PCV side still gets some action though but I'm hoping the ARX cycle I did stems some of that.
    2000 "Amazon" Tropic Green CSVT #836/2150
  9. #9
    Nov 2006
    Colorado
    590
    Update, cropped closeup of the oil separator at 1 week, about 250 miles.
    A half teaspoon of oil perhaps?
  10. #10
    Apr 2008
    North Texas
    3,550
    But that would make a mess if it were still atomized.
Page 1 of 3
1 2 3 LastLast
Similar Threads
  1. Zetec PCV Valve - Could it be any more of a pain???
    By Scorpion8 in forum Zetec Maintenance
    Last Post: 05-04-2010, 03:45 PM
  2. P/N For PCV/Crankcase Gasket??
    By Beans in forum Duratec Maintenance
    Last Post: 03-14-2010, 10:24 PM
  3. Pcv r & r
    By cashflow50 in forum General Troubleshooting
    Last Post: 03-12-2010, 03:02 PM
  4. DIY: An Oil/Air Separator
    By over_30k in forum Duratec Performance
    Last Post: 03-10-2010, 01:03 PM
  5. Replies: 13
    Last Post: 06-06-2007, 09:57 AM
