Page 1 of 2
1 2 LastLast
Results 1 to 10 of 13
Thread: car stalls when put in drive and gas pedal pushed
    Default car stalls when put in drive and gas pedal pushed
    i have a 97 ford contour gl every time you start it it will run fine once you put it in drive and push the gas pedal it stalls. if you let the car slowly accelerate itself with the motor than push gas slowly it wont stall. but you cant even drive it cuz it stalls almost every time. what could be the problem
    Clean the MAF sensor. My car would hesitate whenever I stepped on the gas until I cleaned it.
    Default 97 contour gl stalls when you hit the gas pedal when in drive
    I cant seem to figure out why my car is stalling when gas pedal is pushed. it only stall when gas is pushed when the car is in drive. In park it will idle and run fine except that it you floor it the gas will slowy rev up instead of fast like usual. i checked the tps with a meter its still good i cleaned the maf its fine cuz that was my origanal problem. i changed a rotted dpfe vaccum line and the fuel filter. i am running out of things to try can someone please help.
    i cleaned the maf checked my tps with a meter and changed a bad dpfe vacuum line. im still getting the problem. origanally my maf was dirty and making it do that i cleaned it and it ran fine for a month now its stalling every time gas is pressed but only when its in drive in park it idles fine but when you floor the gas even in park it will slowly rev than go full throttle
    Since you cleaned the MAF have you tried resetting the ECU? Pull the fuses and see if that corrects it.
    Dec 2005
    formerly las vegas, now dallas TX
    3,868
    sounds like a fuel supply issue. when u floor it, ur injectors switch to full cycle. how old r ur injectors? any Check Engine Light?
    Julian
    98.5 csvt #6226 of 6535
    Rally Inspired 3L turbo'd monsTOUR
    Modifications??? well...lets just say this ain'tcha grandma's contour
    Dec 2005
    3,868
    why do u have two threads on the same issue running? mods pls close this one.
    Julian
  9. #9
    Dec 2005
    3,868
    seriously dude. 4 threads on the same topic? whats ur problem?
    Julian
  10. #10
    changed the fuel injectors and fuel pressure is good i did a fuel pressure test check engine light is on but it doesnt give a code it just says dpfe vaccum leak. but i changed the line and it hasnt come back on but my problem is still occuring
Page 1 of 2
1 2 LastLast
Similar Threads
  1. Cant put the gas down. Have to acelerat slowly! Car just stumbles.
    By evoluson@hotmail.com in forum General Troubleshooting
    Last Post: 04-16-2010, 12:51 PM
  2. It's the pedal to the left of the gas pedal
    By mrutkaus in forum General Discussions
    Last Post: 04-02-2010, 09:16 AM
  3. Car shuts off at red light unless I hit the brake and gas at same time!
    By mmayo1129 in forum General Troubleshooting
    Last Post: 03-23-2010, 10:32 PM
  4. Clutch and Gas Pedal Issues
    By Fordwerke in forum General Troubleshooting
    Last Post: 03-10-2010, 08:43 AM
  5. Car reves up when clutch pushed in
    By ford4life in forum General Troubleshooting
    Last Post: 08-14-2008, 12:42 PM
