Results 1 to 7 of 7
Thread: OBD II Code 171
    Default OBD II Code 171
    I have a '96 Contour with a 2.0. Check engine light came on with code 171. Changed the O2 sensors and cleaned the MAF (about 1 year old).
    I looked all over the engine and don't see any visual issues. I changed the fuel filter. Draining it produced some metal flakes, plastic pieces (not much of either) and a bit of water.
    I hooked up a vacuum gauge and at idle it reads between 13 and 17 inHg. Very low in my opinion, but I don't know what it should read. The vacuum was steady , only pulsing as idle speed changed. I looked around some more, but I don't see any obvious signs of a leak. I sprayed carb cleaner at all the likely spots, but no change in idle.
    I would like to test the fuel pressure, but my software won't test, only read. i think I can get a gauge from the local parts store for testing. Is there a way of getting full fuel pressure without a test program?
    Steve
    Jun 2000
    rochester
    401
    There should be a Schrader valve on the fuel rail that you can plug the test gauge into to check fuel pressure
    Dec 2001
    Gales Ferry, CT
    24,906
    Blog Entries
    93
    that vacuum reading sounds good to me. I forget what my zetec was reading, I might have posted it somewhere previously. You can check the fuel pressure from the fuel rail.
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 99 Contour SE Sport <- traded in 2/13
    - 2k Contour SVT - #2137
    Glad to know the vacuum is OK. I am used to SBC's with 20 to 25 in Hg at idle.
    I would love to test the fuel pressure at the fuel rail, but I don't have a way to tell the computer to run the pump at full output. My shop manual says to plug in a guage and then run a pump test via a scan computer. I have scantool, but the free read only version. Is there any other way to test properly?
    Yesterday I tried to pull the car into my garage and it took nearly 5 minutes to get it started. After it started it ran rough for a good 15 seconds.
    Steve
    Dec 2001
    Gales Ferry, CT
    24,906
    Blog Entries
    93
    the Ford manual will call out a idle fuel spec, I would start with testing and see where the pressure is. Then I believe the manual will also give an off idle value which can be checked for by reving the engine.
    - 12 Focus SE
    I guess it depends on the manual. The Haynes guide I have says to test with the engine off. I can test with engine on if someone knows the proper values?
    Default Resolved
    I replaced the fuel pump and that appears to ahve fixed the issue. The engine runs better, no more hard starting issues, and no codes.
Similar Threads
  1. OBD code 171 and stalling/hard to start
    By Srgould41 in forum General Troubleshooting
    Last Post: 02-07-2011, 03:31 PM
  2. what to do for a P1101 OBD Code?
    By dr07 in forum General Troubleshooting
    Last Post: 09-03-2008, 01:09 PM
  3. P0420 OBD-II Trouble Code..great
    By acontour in forum General Troubleshooting
    Last Post: 04-01-2008, 08:08 AM
  4. OBD Code 1744
    By sprindl in forum Duratec Maintenance
    Last Post: 06-06-2007, 07:40 PM
  5. OBD-I code reader - Continous light/beep
    By ck42 in forum Duratec Maintenance
    Last Post: 12-14-2006, 07:30 PM
