Results 1 to 9 of 9
Thread: Gas overflows when filling
    Nov 2003
    Plainville, CT
    8,099
    Default Gas overflows when filling
    My girlfriend has been telling me that everytime she fills up her SVT, the pump shuts off at the top and then gas overflows from the filler neck. This was the first time I had heard of this with a Contour so I assumed she was doing something wrong (i.e. bad angle on the pump, not dropped down all the way). I was with her yesterday when this happened and I checked everything over.
    The pump didn't do the usual problem that people have with it clicking and stopping every few seconds. It filled up perfectly all the way to the top, clicked and stopped but about 1 second after it stopped, gas overflowed from the filler neck and dripped out.
    2000 SVT with only 78k miles.
    Is there a TSB for this? I know there was for the earlier models stopping while pumping. I don't know if this is related.
    1998 SVT Contour 3L (B/MNB) #542 (His)
    2000 SVT Contour (SF/MNB) #1533 (Hers)
    2003 BMW 540i M-Sport (6 spd)
    2002 Cougar XR - XR Racing Red
    2002 Lexus IS300 SOLD!!
    Aug 2010
    Green Bay, WI
    113
    I wonder if something is sticking with the flapper for the fuel neck?
    Nov 2006
    Colorado
    434
    Sounds like the tank isn't venting well. I'd crawl underneath, or since it's your girlfriend's car, have HER crawl underneath and check the condition of the fuel filler and vent hoses between the filler neck and the tank. The vent hose will be the smaller of the two, and it may be pinched or collapsed. 11 years of exposure to fuel can soften up these hoses and make them crack, leak, or collapse.
    Contours have fuel filling problems anyway, usually due to the flapper/anti-spashback valve where the fill hose meets the tank. Usually, they restrict fuel filling speed, I can't have the pump flow on anything but the first, lowest flow setting.
    1985 SVO Mustang (turbocharged track whore), 1989 Taurus SHO (supercharged track whore), 1999 SVT Contour (Sedanus-Grocerygetter-Rapidus)
    Oct 2006
    Las Vegas , NV
    1,266
    Along with the pump shutting off (clicks) when trying to fill. Occasionally mine does this too. Sometime even when the tank isn't filled. Handle will click and fuel will over flow onto the ground under the car or sometime comes out through the inlet.
    To avoid all the issues, I angle the handle to the side, swung clockwise. In addition I take my time filling up and use 1/2-3/4 of the trigger.
    Never felt the need to pursue it. You may find your trouble will come and go as the seasons change.
    Hope this helps
    2000 Tropic Green SVT Contour #455 of 2150
    Born Date: Nov. 19, 1999
    Exhaust | Intake | ATS Complites | Pre-98 trunk w/ Lip Spoiler | A-pillar Gauges | Fidanza Shifter | Ground Control | Koni | Autovation | ED Splitter | Carbon Fiber EVO Hood
    Dec 2001
    Gales Ferry, CT
    24,480
    Blog Entries
    93
    I have had the same thing happen to my 2k SVT also. Haven't looked into it yet. But I believe it only does it when I have tried to top off after the pump has clicked off. Normally it will take some more gas when doing this but not in this case.
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 2k Contour SVT - #2137
    Nov 2003
    Plainville, CT
    8,099
    I'll try to check the vent hose when I get some time. The smaller section of vent hose coming off of the tank is only $31 for a Motorcraft replacement. The larger section is only included as part of the filler neck assembly so hopefully that won't need replacing.
    Is there some sort of a valve on the vent hose? I should be able to disconnect the hose, inspect or clean a blockage if needed and reconnect without anything spilling from the tank, correct?
    Jul 2009
    Bangor, Maine
    1,312
    Same here on my 2000 SVT. When the gas pumps clicks off, that's it. She won't take anymore without spilling.
    2001 SVT Lightning #2839 - Stock
    2000 SVT Contour #1541 - | K&N | FSVT EAP | Hankook K110 | Y-pipe | RSTB | Energy Suspension |
    Nov 2006
    Colorado
    434
    Your girl friend wouldn't be using one of those permanent gas caps would she?
    Similar to this? PermaCap is one of the major brands.
    These have been known to cause problems with fuel fillers that don't vent well to begin with.
    On filling my own 99 CSVT, I've found that not fully inserting the nozzle will alleviate the premature pump shutoff issues. It seems to be related to the end of the gas fill nozzle and it's airflow sensor in relation to where the car's fuel tank vent line connects to the fuel fill tube. The further out I get the nozzle, the less sensitive the pump shutoff is, but I've never had any fuel splash back, and the pump always shuts off well before the fuel comes up in the filler neck.
    IIRC, the Contour/Mystique issues with the flapper valve in the tank filler pipe were related to alcohol content in the fuel swelling the plastic.
  9. #9
    Nov 2003
    Plainville, CT
    8,099
    No, it's just the original factory cap on there. The shutoff seems to work fine, sorta-ish. It only stopped after filling completely and doesn't give any trouble during the fill. It seems like it was just delayed shutting off by about a second causing the spill.
    I took a quick look under the car just now in the dark and I see two hoses. One that runs parallel with the filler neck, and another that runs up top and ends to the right of the filler neck inside the fuel door. Which one is which? I thought of maybe trying something simple like a coat hanger down the hose to check for an obstruction.
    On another note, her rear tires are completely bald on the inside edges. Good thing the wheels and tires are getting swapped out in another week.
Similar Threads
  1. GAS!
    By SVTGeorge in forum Duratec Performance
    Last Post: 06-10-2008, 09:45 PM
  2. Ran out of gas, filled it with gas, won't start!
    By Boise SVT in forum General Troubleshooting
    Last Post: 06-09-2008, 07:31 PM
  3. Filling capacity for air conditioner
    By Speed Demons in forum Duratec Maintenance
    Last Post: 12-16-2007, 08:47 PM
  4. CSVT Gas Gas Mileage
    By csvt2200 in forum General Discussions
    Last Post: 05-04-2007, 02:54 PM
  5. VCD not filling screen
    By hotdimmes in forum Common Interests
    Last Post: 12-18-2006, 09:45 AM
