CEG Forums
Go Back   CEG Forums > How-To's > Duratec HOWTO
Duratec HOWTO HOWTO documents relating to the Duratec V6
Reply
Thread Tools Display Modes
  #1
Old 07-12-2009, 12:41 AM
BoneStock99 BoneStock99 is offline
Default Beginners How To: Throttle Hang Fix
INTRODUCTION
Whether you are fixing a problem, improving performance or simply doing regular maintenance, there is nothing like the pride one feels after having worked on his own car with his own hands. If you are not mechanically inclined or simply lack experience but want to get started on doing your own work, fixing the throttle hang on the contour V6 is a great project to get your feet wet and build confidence.
The throttle hang experienced by V6 contours is annoying but fortunately, the fix is extremely simple, inexpensive and takes very little time.
So...
In recognition that not everyone is comfortable under the hood of a car and that many of those who are not would like to be, The Contour Throttle Hang Fix is presented here for your edification.
BACKGROUND
You may want to read the article at http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=3 and that may be enough for you to have a go at it. If you are still shy, fear not and read on.
THINGS YOU WILL NEED
You will need a V6 Contour of course. An SVT is preferred but a non-SVT will work just fine too.
You will also need some 1/2 inch diameter pipe caps, available for about fifty cents each at the home improvement store.
You will also need a selection of tools. The picure shows just about every tool you could possibly need. At a minimum, plan on having:
- A drill
- 3/16" and 7/32" drill bits if you have an SVT
- A 15/64" drill bit if you have a non-SVT
- A pair of pliers or a bench vise, extremely important so you don't injure yourself!
- Flat blade screw driver
- Electrical tape
WHERE UNDER THE HOOD WILL WE BE WORKING? IS THE SPOT EASY TO GET TO?
We will be working under the hood in the location shown below, at the rear of the engine compartment, slightly to the driver's side of center.
The silver "Flying saucer" shaped part is the Exhaust Gas Recirculation valve (EGR valve). The brake fluid resevoir is to the right of the EGR valve, pictured with the black filler cap with a yellow sticker on it. We will be working on the rubber hose behind the EGR valve and next to the brake fluid resevior. The location is very easy to get to and is shown in the picture below.
To prevent scratching the paint as you lean into the engine bay to work, you may want to put a soft cotton towel over the fender and take off or cover any metal belt buckles, zipper pulls or pocket rivets on your jeans at this time.
PROCEDURE
STEP 1. Start with a clean and safe work area.
STEP 2. If you have a centerpunch and hammer, make a small identation on one of the pipe caps so that the drill bit has a place to sit when it starts turning. Doing so prevents the drill bit from "Skating" off to the side as you start to drill.
Remember that copper is an extremely soft metal and so you will not need to hit the centerpunch hard to make even a slight indentation. Tap it lightly and if you need to, you can tap it harder a second time until you get it right. It is best to do this to two of the pipe caps at this time.
Step 3. For safety reasons, do not hold the pipe cap in your hands while drilling! If the drill bit should slide or "Skate" while you are drilling, it could cause serious injury to your fingers or hands. This warning should be enough for you to want to hold the pipe caps with something like a pair of pliers. If you have access to a bench vise, that would be the best way to go.
Again, note that copper is an extremely soft metal and so sqeezing the pipe cap hard with pliers or a vise could easily crush it.
For an SVT, drill a hole into one of the pipe caps with a 3/16 drill bit and drill a hole into another pipe cap with a 7/32 drill bit. For a non-SVT, drill a hole into the pipe cap with a 15/64 drill bit.
The drill bit may bind in the hole it is creating just as it is completely breaking through the metal. The pipe cap may try to twist out of the pliers when this happens. It is important to grip the pipe cap firmly enough to prevent this from happening while not gripping it so hard that you deform it's shape. A feel for how hard to grip it can only be learned from experience so if you are not used to performaning this type of mechanical work, be prepared for it to happen.
It may seem obvious to experienced mechanics but to the beginner, it needs to be stated; if the drill bit binds in the hole and the pipe cap gets stuck on the drill bit, UNPLUG THE DRILL BEFORE TRYING TO GET IT OFF!!!
For safety reasons, use a bench vise if you have access to one, instead of pliers.
You can use a little sand paper to sand off any burrs or sharp edges left over from drilling if you want. At a minimum, make sure that no loose burrs or sharp shards of metal are left hanging around which could get sucked into the engine. You do not want metal shards getting sucked into your engine!
Step 4. Loosen the hose clamp which holds the rubber hose in place. The location is pictured below. You will not need to completely unscrew the hose clamp; just loosen it enough so that you can wiggle the hose and slide it off.
Step 5. Slide the hose off of the metal pipe to which it is mounted. You may need to wiggle it a little to get it loose. Don't be afraid to pull the hose off; this is an air hose so no fluid will leak out.
Be sure not to let the hose clamp fall off into the engine bay! The engine will not run properly without the hose in place and you could get stuck without it properly attached.
Step 6. Push the pipe cap down into the hose with a finger and check the fit at this time. When installed, the pipe cap will be pushed about three quarters of an inch to one inch into the hose.
It is important that the pipe cap fits snugly and that it does not rattle around inside the hose or cock to one side and completely block air flow. In the picture below, you can see that the cap isn't quite big enough to fill up the entire hose. Note that the hose, having been stretched open at it's mounting point, may be have a slightly larger diameter at the end and a slightly smaller diameter further down where the pipe cap will sit.
CONTINUED NEXT POST
__________________
Jesus built my hot rod...
'99 Silver Frost #634, Just like the screen name says.
2001 Fuji Roubaix 27 speed (bicycle), 38,000 miles.
  #2
Old 07-20-2009, 02:35 AM
Default
CONTINUED FROM PREVIOUS POST
It is likely that the pipe cap will not sit snug in the hose as pictured above. If the pipe cap is not held firmly in the hose, pull it out with a pair of needle nose pliers and increase the diameter of the pipe cap by wrapping it with a few layers of electrical tape as pictured below. In the application pictured, three layers of electrical tape were sufficient. You may need more or less tape depending on the condition of the air hose.
A proper fit is pictured below.
Push the pipe cap down into its permanent position in the hose as pictured below.
Step 7. Push the hose back onto the inlet from which you removed, it, slide the hose clamp into place and tighten the screw. Do not overtighten the hose clamp. It does not hold high pressure and only needs to be secured so that it does not vibrate off as you drive. Simply tighten the screw until snug and then give it an extra turn or two.
Step 8. Clean up and enjoy.
ADDITIONAL NOTES
Ray McNairy's comments in the original How-To document at http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=3 mentions two different hole sizes for the SVT, 3/16 and 7/32, both of which are noted in this document. Evaluate both sizes for optimum performance in your car. In the words of Mr. McNairy, "I would suggest getting several plugs-they're cheap-and trying different size holes. It needs to be just large enough to maintain cold or warm idle RPM's under worst case accessory loading. I assume this is cold day, cold start with the air on in defrost mode."
Ray recommended (temporarily) removing the fix when taking the car for your state's emission test.
On a personal note, it is my opinion that the improvement this fix makes is not to be underestimated. The quicker drop off in revs when shifting the SVT means that the next higher gear starts a little lower in the RPM range. The car just feels like it has way more torqe. To me, it felt a lot more sporty, like it could be driven much harder. I used the smaller hole first, switched to the larger hole and then went back to the smaller hole again.
Good luck, have fun and be safe.
-Tim-
__________________
  #3
Old 08-25-2009, 05:57 PM
Clafong Clafong is offline
Be Gentle I'm New here
Default
even if this doesnt work for me, this is a very nice arctile
thanks a lot
My Contour used to Moose, I had the Ford fix done (FSB). Not sure if its still available but it did work
I finally bought a Kurtz intake and now my moosing is back
I'm going to try this and see how it works
thanks again for a nice beginner artilce
  #4
Old 09-10-2009, 02:15 PM
ghent96 ghent96 is offline
Send a message via ICQ to ghent96 Send a message via AIM to ghent96 Send a message via MSN to ghent96 Send a message via Yahoo to ghent96 Send a message via Skype™ to ghent96
Default
The link for the background on this in the original post isn't working.
How do you know if you have a throttle hang?
__________________
2000 Mercury Mystique LS 2.5L V6 Duratech ATX 110k - black
  #5
Old 10-18-2009, 02:42 PM
xOZx xOZx is offline
Default
Quote:
"Throttle hang" refers to the engine taking its sweet-a** time to drop revs after taking your foot off the gas pedal when initiating an upshift. It seems to pause for a second or two before it "realizes" you've taken your foot off the throttle.
Not sure if it also happens with an automatic transmission...
  #6
Old 10-20-2009, 04:14 AM
Default
aha, thanks, now I understand. So on an ATX it could be a little lurch or unevenness as the car shifts that seems to be tied more to the engine RPMs, rather than a transmission problem. (?) When not shifting, but merely letting off the gas, I'd guess the symptoms would be exactly the same as you describe above.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Beginners How To: Throttle Hang Fix BoneStock99 Duratec Performance 2 07-15-2009 03:54 PM
Throttle Hang fix cotcu New Member Classroom 2 07-12-2009 07:09 PM
About that throttle hang fix... Epheron General Discussions 5 02-03-2009 12:42 PM
Throttle Hang Fix Dyoel182 Duratec Maintenance 16 05-08-2008 12:43 PM
SVT Throttle body install how-to Ray Duratec Performance 0 10-09-2007 01:09 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
