Group buy is open.
These will be made in groups of 3 or more soo what that mean is I will not order the parts for just one setup. It will be first on the list first to be made. Obviously it takes time for me to make these, and get all the parts. Like with all of the Skunkworks Autosport group buys updates will be posted in this thread.
When there is 3 or more people I will inform those people where to paypal including shipping. When you put your name on the list also post your zip code.
You would have a few options as far as mufflers,resonators, cats and tips, also would be 2" piping. This would be for under the gas tank as pictured. Obviously if you wanted a H pipe it would be more as well as certain other features. All the bends would be mandel not crush bends.
Could possibly work out something so that it bolts to the back of the Nautilus Performance down pipe for the turbo kit to make use of the 2 2" pipes.
Remember this is a true dual kit that will show up at your door that you can bolt on yourself. Not have to take it to a muffler shop. No other company is offering anything even in the same neighborhood as this.
Many CEG'rs have paid over $1200 for custom true duals. Obviously I should state that this would be for offroad use only, especially if you where to go without cats.
Off the top of my head these are the company's that i would deal with.
Spintech
Vibrant
Thermal
Magnaflow
Dynomax
Dr. Gas
Alright I have priced everything out and this is what you would get.
An Aluminized 2" tru duals with flex pipes, all mandel bends, the pipes to connect to the exhuast manifolds/headers, Spintech or Thermal mufflers and choice of tips. It will show up and all you have to do is bolt it up to the manifolds, put on 2 exhuast clamps(or have it welded) and hang the exhuast.
You choice of tips
http://www.thermalrd.com/tips.htm
http://vibrantperformance.com/catalo...38fd78287c77cc
$650 plus shipping
If you want to add on parts heres the prices
Cats $180 for vibrant High flow ceramic cats
H pipe $100
Resonators depends on model wanted
Extra bungs $25 dollars per bung
Different mufflers? If you want Different mufflers remove $125 from the price then add the cost of the ones you want.
Full Stainless steel exhuast? I can get cost put its probably gonna be cost to double
Attenion!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Disclaimer: This dual exhuast passes under the gas tank. Skunkworks Autosport and Myself are not liable for imporperly installed exhuast systems. There should be a heatsheild installed to minimize the amount of heat that is transfered to the gas tank area. Improperly installed exhuast systems can lead to melted gas tanks and a fire hazard. If Skunkworks Autosport feels that you do not have the mechanical apptitude to install this exhuast it will not be sold to you.
Pictures:
Video is of a 2" Tru dual with 2 18" magnaflow resonators and 2 spintech mufflers
Tru Duals with Magnaflow:
Spintech
Vibrant
Thermal
Magnaflow
Dynomax
Dr. Gas
You choice of tips
$650 plus shipping
H pipe $100
Pictures:
