Tour_Racer00
Ok, so I put in a new SPEC stage 1 clutch along with a new SPEC flywheel in July of last year, drove it with no problems for a couple thousand miles and then it went into storage for the winter. Brought it out this April, put another couple thousand miles on it and about a month ago I started hearing a moaning sound whenever the clutch was slipping and it was "cold". There was a video of it somewhere on CEG that sounded exactly like it but I can't find it. I put it away for a couple weeks and when I came back to it last week, I got out on the highway and doing 65 MPH if I floored it in 5th gear the clutch would slip for a second then grab. Now unless it has been used hard and warmed up, it slips whenever it gets full throttle. The car did see one track day where I made 5-6 passes and then the random 10-70 pass here and there but since its a performance clutch and drivetrain, I thought it could handle it. Now I have 4,370 miles on my entire drivetrain (flywheel, clutch, tranmission, axles, ect.) and the clutch is giving me more problems then I have ever had with the entire car since I took it out last week. I called SPEC and they gave me the 120 day bs (the damn car was in storage longer than that) and I let it go at that without a fuss. Basically I want to figure out why it is doing this and what I need to do to fix it. Has anybody else had this kind of problem. Some people talk about physical damages to SPEC clutches because of a revised disk but I don't think this is that kind of problem. Suggestions?
