Myrosia
Ford Contour L4-122 2.0L DOHC SFI.
Manufactured: 10/98
130.000 miles
I took the car to the dealer for the 1-2 bang shift and leaky TSS. Thought it was the TSS although, the tech said that the PCM had to be reprogrammed and the TSS was fine and he would repair the leak. cost = $190.00
Other issues:
1. The tech said 3 mounts are bad. Front, back, and tranny mount and it would cost $700.00 to replace.
Is this a reasonable price or is this an easy driveway DIY?
2. The original tranny fluid is in the tranny. I use to hear that if you have never changed the tranny fluid and you are at 100.000 miles, then never change it because it could cause future damage and tranny failure? cost = $125.00
Is this true or not?
Thanks
Manufactured: 10/98
130.000 miles
Other issues:
Thanks
