BurritaSVT
Ok guys I finally made it but only did the four manifolds. The taurus 2001 is just torque the taurus 2004 made good power but the rpms were jumping around on the dyno giving the spikes but it you look at the chart you will see that is made 198whp with 197wtq. The mazda6 intake same escape did better overall minus torque but was solid across the board where the tuarus 2004 had a midrange torque hump but fell short of the mazda 6. My analysis is the SVT cams and escape UIM will perform the best all around. here are the dynos
the first pull was mazda6
second pull was taurus 2004
third pull was taurus 2001
fourth pull SVT UIM no Secondaries
The A/F were very close same tune same timing across the board
