sleepr
Check this ad out (edited to protect the potential buyer
It's several hundred miles away, so I haven't been able to lay eyes on it. I believe that this is the same RFF, non-VVT engine as in the Taurus, but I'm not sure about water pump config or intake manifold clearance. Does anyone know any reason that this can't work for a full swap? :shrug:
Thanks!
ps: I've never seen so many "do a search" responses as on this Duratec 3L forum. Way to be helpful, guys. How about putting some practical info in the stickies regarding the different 3L engines, year over year changes, what parts must be transfered over and why. A search for this info is pretty useless. :crazy: :help:
This is a low mile 3.0 DOHC engine out of a 2005 Ford Five Hundred. Engine was test run before pulling. Compression is 200-210,oil pressure is 60#s hot. Mileage is 20,000. $250.00
Thanks!
