WiredMotorSports
3 Kits for 98+ availible.
PBS Kit1 ((98+ only/pre98 plugs not here yet))
~This kit will plug directly into your orig ign. plug (aprox 4" down from key)
~This will aslo turn off your acc. when starting as to not damage any of your acc. (radios, nav. , and many others can be damaged from any volt. drop or spike during starting.
~Will have option to enable/disable key start
~NO momentary button sold with, Use which you like best. all you have to do is gound it out. I will locate which wire will illuminate only when motor is off.. this way your button will only light up when it needs to be started...and off when running (( basicly the alt light on your dash, or Oil light))
(($60-Shipped))
___________________________________________
KIT ONE..
This is with the Push button I had already... no word yet on These above....
Feel free to go threw the pictures once opened. They were of the instal.
(((WARNING: door was open, ANOYING DINGING!!!)))
((kit 2 showed no promiss of a constant reliability with key placement... Put off for now))
(($60-Shipped))
KIT ONE..
