Eeek. I saw Precision Turbo and thought about the horrible eBay ripoffs. Tell me I'm way off!
Hope not. That was an NPG kit.
Bugzuki: Found some more pics, may be helpful to you.
EGR Tube fabrication. Basically spliced together the 3L and 2.5L tube so that I had the DPFE sample leads plus enough length to reach up and through to the front of the UIM:
Welded a piece of plate steel to the end to provide a mating surface to the EGR valve, and threaded the holes:
Came up right where I needed it to use the stock 3L EGR valve:
Fuel rail: We used a hunk of 3/8" SS brake line, and silver brazed connections and used compression fittings to mate it together. We used the 3L rail, cut off the stock connection, drilled a hole in the other end of it to act as the return, and silver brazed a brass elbow to each side of it:
We then bent the SS line around and back to where we'd cut a stock 2.5L rail off, and mated the two together:
Fit nicely:
The thing didn't leak 1 iota until the owner had driven almost the entire way from DC back to Atlanta. I guess there was a pocket of flux from the silver brazing that the gasoline finally ate through. As I said, we didn't have time for a shakedown before the guy had to go back home...
TB Bracket: Hacked the ends off a stock 3L bracket leaving only the mounting holes and a place to mount the similarly hacked piece of a 2.5L bracket. Cut a triangular brace out of what was left, and welded the whole thing together (I love TIGing):
I had to effectively make the stock 3L TB cam larger in circumference, so I dremeled holes through it and used stainless nails as a "guide" of sorts to make the outer track wide enough to use the SVT throttle cable.
