Hello all.
I've got a '98 SE with 130k. The other day, it refused to start. Cranked like a champ, but wouldn't start. I suspected no fuel was getting to the cylinders, so I spent a few minutes perusing the forums.
After reviewing a few threads regarding fuel pumps, I went back out to the car and turned the key while carefully listening for the priming 'hum'. No hum. One thread mentioned whacking the fuel tank with a mallet to 'unstick' the pump, so I did. It actually worked. Car started right up.
I assume the pump is beginning to die, and I'm wondering if there's anything else I should/could do apart from replacing it. Replacing it is not a problem, but I thought I'd first check to see if there's something I can do about the pump's intermittent failure to do its priming action.
I've looked at the how-tos and other threads regarding pump replacement. Seems fairly straightforward.
Anyone have any input before I order a new pump?
Thanks!
Thanks!
