What's even better is to line the entire inner side of the mirko with peel-n-stick felt from Michaels.By the way install a thin sheet of foam on the sides. So it doesn't tear up the paint from rubbing with the fiberglass.
The what?also if your bumper doesn't have the stays at the corners get them, it will make the bumper more stable ...
And the holes you have to drill with the Dzus's are like the size of a nickel right?
