| Register | Projects | Blogs | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
| Transaxle MTX-75 and CD4E modifications and maintenance. |
Thread Tools | Display Modes |
#1
here are some pictures that I took of the clutch, etc. I got lucky and the pp and flywheel where not damaged. I wonder how long some of the springs have been free and for a long time, from time to time I would get a grinding like noise on clutch engagement and sometime the clutch would grab really fast, or lower then normal. I have also had a squeaking type noise for a long time, I figured it was the tob but it seemed ok when I checked it.
__________________
- 95 Mystique LS - 99 Contour SeVT <- 3L/NPG Turbo - 2k Contour SVT - #2137 Aircougar Performance |
#2
pretty...... perhaps spec clutches have problems with the friction discs.... will they give you a new one? what about a new disc from clutchnet.com?
Good luck major bummer
__________________
'00 Toreador Red (1842) 3Ldead ![]() '99 Silver Frost (2665) (Barn Find) SVT "Project" '99 Silver Frost (?) For Sale I have E0 T-red/MNB CSVT Parts |
#3
Quote:
just got it out tonight so I still have to call and find out. but the spring retension design is crap. if I put another one in its going to fail the same way.
__________________
#4
which is why I was suggesting a clutch disc from clutchnet.com as I thought you might be able to get a comparable disc with out the flaw and keep your spec pressure plate..... good luck though... I've had no problem with my spec stage 2 *knock on wood*
__________________
#5
Quote:
__________________
2000 Silver Frost/Midnight Blue #564/2150 2000 Toreador Red/Prarie Tan #576/2150 Project: Tour De Force, Revived 4/25/09 1999 Mystique White/Prarie Tan Zetec ATX 55k (sold) |
#6
call clutchnet ask them for:RED disc. 6 puck, ceramic metallic, closed window, sprung hub. tell them to use huge rivets too. 168 bucks +shipping for the disc.
__________________
98 CSVT-black. on it's second 3L swap. 219hp/211 trq |
#7
what pressure plate are you using with it? how is the driveability?
__________________
#8
aw man, that's what was going on with your clutch.....
![]() ![]() ![]() ! Atleast you have it figured out now, but spec is really starting to piss me off with these failures .
__________________
Senior Qualified Member
JOE'S POWDER COATING - PM ME OR CLICK HERE FOR MORE INFO Don't put your finger where you wouldn't put your face..... 95 SE 3L WITH MATCHING TRAILER |
#9
Quote:
yup that was the problem. from what my father and I can figure when I bleed the clutch I got 100% movement from the tob. this was enough to clear the springs and allow the clutch to work correctly. the rest of the time the popped springs kept the clutch from releasing completely so that I could shift.
__________________
#10
Quote:
__________________
00 SVT Silver Frost/Midnight Blue #1321/2150 99 Cougar V6 5spd Spruce green - SVT powered! 03 F150 4.2L 5spd Supercab Black I guess I have a thing for V6's with manual transmissions? ![]() www.shineyphotos.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| duratek, 1995, lacks power | peecoman | General Troubleshooting | 7 | 08-10-2008 05:07 AM |
| SPEC Clutch and Flywheel Prices *NEW* | SVTCuervo | Group Buy | 10 | 07-01-2008 08:03 PM |
| FS: Spec stage 3 clutch | Hammy1105 | Performance | 0 | 06-28-2007 12:50 PM |
| Clutch Chatter with a SPEC Stage 1 and SVT Flywheel? | seabass_00svt | Transaxle | 15 | 03-17-2007 11:55 PM |
| Spec Stage 3+. Is that too much???? | detroitsvt | Transaxle | 10 | 10-13-2006 04:56 PM |
