trhlz1222
well i got the radio problem fixed but now another problem arises. the headlights wont turn on. fog lamps turn on, and the parking lights turn on. low beams and high beams dont even when you use the flash button. all fuses are fine. all relays are fine. all bulbs are fine. i put leds in my cluster a long time ago and one blew so i switch it with another one in the cluster that is never used and since i did that they wont turn on. i switched my blown turn signal one with the one for the high beam symbol. after that i turned the lights on to see if the leds worked and they didnt but the lights did and then went out. i put the leds back in their normal position and checked all fuses and relays and still nothing.
