MAF Adapter Question.
LGR Mystique
My question about the MAF Adapter is...is it a 3" opening, or 4"? I found a near by performance store selling them for $30 CDN.
3" is smaller than the MAF! The OEM MAF entrance is 84mm.... so you'll want a MAF adapter for at least a 3.25" air filter (still smaller), but 3.5" would be better.
Are you sure their adapters are for your car? The adapter entrance ID should be bigger than 84mm (3.3")... or else you just installed a restriction. For reference, the Mirko adapter has a 91mm OD (3.6"). The OD of the BAT adapter is 85mm (3.35").
Wait.... is this for a zetec or duratec? The above comments are for the duratec only. You really should have posted this in the relevant forum.
Zetecs don't use a MAF adapter, they already accept a 3" filter.
Get a decent MAF adapter made for the duratec, not some autozone junk (if it even fits at all). It'll cost you maybe $20-$40. Then you can run a correct sized filter like the 3530 with 3.75" ID.
