me too....
me too....
I am having the same problem where I can't get my trunk open.
The actual lock is gummed up. I have tried lubricating it several times, and can't even get my key in.
The key fob also doesn't work, I push the button, no sound, nothing.
The pull lever was working until this weekend. It was working barely, I would usually need someone to pull the trunk lid up while I was pulling the lever up. Probably need to replace the shock lifters.
To complicate things further, I took apart the pull lever to see if the problem was the cable needing adjustment. In the process a plastic piece broke off that holds the cable in place.
One positive is that I can get into the trunk via the fold down seats. Is there a way to pop open the trunk from inside? There is a piece of plastic molding along the bottom of the inside of the trunk that I can try removing, hopefully I can get to the lock or cable from there. I will try that tomorrow.
My goal is to get one of the 3 methods of opening my trunk to work. The Ford dealer didn't seem confident they could fix it until the trunk was actually open.
Any help would be greatly appreciated. :help:
