A3ON
i decided to pull my Y-pipe off today and look what i found
when i 1st pulled my Y-pipe off
what fell out
runs 10x better
what fell out
runs 10x better
You **** your precats. CEL is on it's way.
His sig says he has a 95, OBD 1 guys. I have 0 cats on my 95 mystique and no MILs, runs fine. I suspect he'll be just fine.
From what I understand, MIL's are for the O2's after the cats. The rear O2's basically tell if you have converters or not.
Correct, but if I'm remembering correctly (and I'm quite tired so maybe not) OBD 1 doesn't use the O2 to trigger CEL's, just monitor the exhaust and help the comp. control fuel. OBD2 has upstream and downstream and compares the readings from each to determine if the cat is functioning properly, if not, it triggers a MIL.
you know after looking at these pics. would a 99 throw cel's if mine were clogged or fell apart?
