Hello All,
First time poster. I am bewildered.....Left the Drive thru, no previous problems, All of a sudden I notice both the speedometer and the tach drop to zero and odometer freezes. Then 30 seconds later the car starts to buck and buck and it was very hard to get it back to the office. I had to keep pumping the gas and shifting it in and out of gear to keep it going. It was jerking very bad like something was shorting out. Get car to office lot and let it die. It will do nothing but click, like low battery. Battery just 6 months old. Let car sit for 45 minutes and go out to try and car starts smoothly. No jerks just smooth idle with hood up. Measure across battery and it is 11.75 volts and then as I continue to watch it, 30 seconds later engine starts jerking violently as before and I measure across battery at it is only 7 volts and then the car died. Now it will not start at all. Acts like battery is being dragged down to nothing. Any thoughts guru's that link the speedo, tach, odom and jerking of engine with battery drain?
