csvtjohnga
235/40/17
how wide are those wheels?
They are 235's, Lol, in which this whole thread is about. :troutslap:
I beleive i said WHEELS we know how wide the tires are...
Right back at ya :troutslap: :laugh:
But by the way, I used to have the same centerline storms, and they are 17X7 with a 42mm offset.
And to the original poster, an 8inch (235mm) tire will fit fine on a 7inch rim. Look at CSVTJOHNGA's pics!
My main concerns are:
(1) Will a 235 wide tire fit on a 7" wide rim?
(2) Will it rub anything?
Pudmunkie said:They may work better on an 8" wheel, but they fit a 7" wheel fine. This is what they look like being mounted. Total width once mounted and filled with air was 8.5". Granted that will vary from tire to tire, but the hankook ventus rs2's are 8.5
Zero .Beans said:I like the look of that lot, no rubbing?
Has anyone run this size on a 17x7" 45mm offset rim? Particularly while lowered?
I'm wondering if I should do this or 225/45 or 225/40.... really concerned about rubbing (Eibachs and BAT's).
Thanks guys!
most people recommend using 225/45 with 17's
I believe 17's with a 40mm height keeps the same speedo accuracy ect... I am buying 235/40/17s for my Oz's.
The height is a ratio of the width.....
I know this post is getting old, but has anyone run a 235/45/17? That's a bit taller, the tire model I'm looking at has it as: 25.2 overall diameter and width at 9.3 where as the 235/40/17 is at 24.5 od and 9.5 width. That might not be much of an improvement over the 225/45/17 though in that it's only .2 inches wider and the 225/40 has an od of 24.8 :shrug:
I'm planning on keeping my stock springs for the near future though so I want tires with some meat on em
