xtascox
Since I bought my 98 Mystique over a year ago the IMRC would stop working after opening the secondaries 2 or 3 times. I never really looked into it until recently and now the IMRC has not stopped working since! It cost me $0 and only about 15 minutes, so before you go and replace the main transistor or even the whole box try this first. It's basically just cleaning.
Items needed:
Rubbing alcohol
Lint free cloth
Rag
Phillips and flat head screwdriver
1. Disconnect negative terminal on battery.
2. Remove the plastic cover on the front of the engine that covers the water pump belt and the IMRC housing and LEAVE IT OFF. If you take it off right after running your car, you will see why. It traps a ton of heat underneath and since I work with computers everyday, I know that heat and electronics do not mix.
3. Take out the 4 screws holding the metal plate on the front of the IMRC box.
4. Remove the metal plate. It may have a "glue" seal on it so just carefully use a flat head screw driver to pry it off. If your engine was running not long before you did this, you will really feel much heat builds up in the box.
5. Now check the back of the plate for excess glue that has run towards the middle and was not part of the seal. Clean it off, using a little rubbing alcohol and a rag, and make sure to get any excess off. Mine had a huge glob running from the outer edge to the middle of the plate. Probably caused some problems.
6. Take a lint free rag and some rubbing alcohol and gently clean any dirt off the back of the circuit board inside the housing. There was some brown residue(probably from the excess glue) across a few solders on mine, probably another problem. Make sure only to use a little bit of alcohol when cleaning it.
7. After making sure everything is dry, reattach the plate and return all 4 screws to their original holes.
8. Take it for a test drive and see if it fixed your problem!
			Items needed:
Rubbing alcohol
Lint free cloth
Rag
