Telegrapher
New CEG'er
- Joined
- Jun 16, 2007
- Messages
- 14
1996 Contour 2.5 L
Has anyone fixed a rough idle condition by replacing the MAF sensor?
Tks.
Tks.
1996 Contour 2.5 L
Tks.
still sounds like a vacuum leak to me
I discovered one cam had slipped out of alignment, so that was corrected.
please explain this more, did you retime the engine?
I consulted with two Ford journeyman mechanics. They both said it is not uncommon for a cam to slip out of time. The cam timing sprockets are not keyed and slip.
I'm told the typical symptom for this is poor acceleration, but I didn't have that problem. After correcting the timing on my car, the idle improved slightly.
Almost everything I've done so far has improved the idle slightly. However, it still isn't right.
