Wow so much good information here, so glad to find it. 11/94 V6 mystique auto with much the same symptoms as described for VSS problems in this forum: bumping speedo needle which finally stayed at zero, clunky shifting, rough running/missing, low power.
So, after reading stuff here, ordered a VSS (the kind where speedo cable goes into the VSS), be here next week.
But also, noticed speedocable broken where it enters the "upper" cable near the brake booster.
Question to the intelligensia: What is the typical early '95 (before 2/1/95) VSS failure?
I can see that if something is stuck/jammed INSIDE the VSS, it could cause both cable breakage and the electronic sensor problems, but obviously just a broken cable would not affect the other job of the VSS, or would it?
Thanks,
Mike
Winchester VA
Thanks,
Mike
Winchester VA
