ahowie
i live in michigan and i want to put a remote start on my car.. went to the store and they said since my car is a manual they cant install a remote start, can i do it myself? are there only certain alarms that will work for a MTX?
i've thought about doing it, but i have a habit of leaving my car in gear all the time, i never really use the e-brake unless i leave the car running to go do something quick. i would guess the remote starts would have some sort of built-in safety feature so the car would not start while in gear.
you can get some remote start units that require you to put the e-brake on, leave the car running and then get out and when you shut the door the car locks and arms itself that way you couldn't really screw up leaving it in gear....
I had a Design Tech remote start unit added to the alarm system on my last car that had a manual transmission. It was fool proof but not idiot proof. The process that you had to follow when exiting your car was:
1) park car with e-brake applied, car in neutral, engine running.
2) throw toggle switch to tell system to take over ignition.
3) turn off key, remove it (engine is still running)
4) exit vehicle, arm security, turn off engine from remote
If the next thing that happened with the security system was not pushing the button to start the engine (such as disarming the system or opening a door using the key to unlock which should trigger the alarm), the remote start was disabled.
This system was fool proof, but not idiot proof. If you correctly followed the steps to activate the remote start but left a window down so you (or someone else) could reach in and place the transmission in gear, the system would still briefly attempt to start the car, causing it to lurch. Fortunately I had a proximity sensor in addition to the shock sensor so if anyone stuck their hand in an open window while the system was armed, the alarm would sound anyway thus disabling the remote start.
Also, if you happened to not go through the process above to turn off your car, you could not use the remote start either. This was irritating at first, but I quickly got in the habit of going through the steps every time I left the car. It was not a big deal, though I occasionally got some funny looks in busy public parking lots
well i dont let anyone drive my car, and im not too worried about leaving it in gear. i always use the e brake anyway, ill just put a sticky note on my door handle or something about leaving it in neutral.. haha but i have called like four places and they everyone says they cant do it. maybe i should just do the install myself.
personally i would not recommend doing a remote start by yourself if you have never done one before... you can screw up a lot of stuff if you connect the wrong wires up and with a chipped key i am pretty sure a immobilizer bypass module will be required along with a 3rd key that is chipped and programed....
Actually not.... 1. the most you ever need for doing fords is 2 keys..... 2. the 1100F PATS bypass module used 4 wires on my pats plug and claimed it needed 2 keys to program buy my car only came with one... and it programmed just fine with one key... the newer XK series immobilizer bypasses made by express kit should be able to bypass strictly on data and are much easier to use than the 1100F PATS bypass...
ahh yes i did forget about the new bypasses that just came in....but regardless i wouldn't even think of doing one myself and i am even a certified installer thru MECP....
You should be able to handle remote start installs then....
I think I'll be able to do this in my cougar... I'm willing to give it a shot anyways, I'm not completely retarded. I have the PATS bypass now. Just looking at getting a remote start setup, no alarm. Looking at this one I think:http://www.cartronixplus.com/templa...mpustar 2w900fm-s MT 2 way remote car starter
yeah im sure i could but do i really want to??? lol no
Or for like $20 more you could get the viper 791XV, 2-way remote, remote start/security w/ shock sensor
http://www.cartronixplus.com/templa...Viper 791XV 2 Way Alarm and Remote start unit
