Whats A Iac I Got A Check Engine Light Code Of P1131 Basically Says My Car Is Runnin To Lean Or At Its Lean Limit It Runs Very Sluggish I Heard It Could One Of The 2 O2 Sensors One On Exhaust Manifold Otehr Just Under It There Is A Surge In Accleration And Sometimes Jerkin Or Shaking.... I Replaced Fuel Pump That Aint It Fuel Injectors? Anyone Know Plz Ineed Help
How old is the Bank 1 (firewall side) Upper O2 sensor? If it is more than 75K miles, then you may want to change it.
From TSB, go through the cheap and easy ones first.
P1131 - Lack of HO2S-11 Switch, Indicates Lean.
When an HO2S sensor indicates lean at the end of a test, the system is trying to correct for an over-lean condition. The code is set when the fuel control system no longer detects switching for a calibrated amount of time.
Electrical
· Short to VPWR or VREF in harness or HO2S
· HO2S circuit shorted to Ground
· Water in harness connector
· Open circuit
· Corrosion or poor mating terminals and wiring
· Damaged HO2S
· Damaged PCM (other DTCs should be present)
Fuel System:
· Excessive fuel pressure (stuck fuel pressure regulator, restricted fuel return lines, etc.)
· Leaking/contaminated fuel injectors or fuel pressure regulator
· Low fuel pressure or running out of fuel (fuel pump concern, fuel supply line restrictions, low fuel level, etc.)
· Vapor recovery system (stuck VMV, etc.)
Induction System:
· MAF contamination
· Air leaks between MAF and throttle plate
· PCV system / Other vacuum leaks
· Improperly seated engine oil dipstick
EGR System:
· Leaking gasket
· Stuck EGR valve / Leaking diaphragm or EVR
Base Engine:
· Oil overfill
· Incorrect cylinder compression
· Exhaust leaks before or near the HO2S
· Secondary air stuck on
