Wow, this thread just reminded me that tom was going to make them. I was supposidly on the group buy for it but I never heard anything on it as to where/when to send money. Sucks =(
News Flash for 95-97 Tours..... I just completed my auto down on pass side harness. This process is really easy if you have access to an extra drivers harness with the relay. After doing the pinouts previously posted I cut out the wires for the auto down relay, and window motor making the wires as long as I could so I wouldn't be short. The power wire - purple/blue I cut it long on both sides of the splice w/ purple/orange that goes to the relay. As in my previous post about the hole already being in the door, I just figured that the wires then have to go in the same location as in the drivers side harness. I matched up the window motor wires and that puts the relay wires in the correct spot, at the junction with the speaker and mirror branches. I then unwrapped the pass harness and started with the window motor wires.
1) picked a spot and cut the white/purple (check pinouts in previous post) to the motor connector then then connected the white wire to it.
2) picked a spot and cut the yellow/purple to the motor, removed the pass motor connector. Connected the cut y/p wire to the yellow/green from the relay connector. You should now have the new motor wiring (cut out of the driver side) back in place.
3) with the motor connector in place now ran out the wires for the relay and they laid up wanting to turn out right at the junction of the mirror and speaker wires, so I knew they were in the correct place. striped a spot on the purple/white about 3/8" long (dont cut it), and soldered in the trimmed and striped purple/blue wire. This was toward the switch on the p/w wire from the relay wires purple/orange splice into the purple/blue.
4) cut other side of the purple/blue at the end of the covered splice with purple/orange and taped up the end so it is protected.
5) picked a spot and spliced the black wire from the relay in the same way.
6) retape the harness and install.
This all sounds difficult when you read it but if you were doing it with everything in front of you the it makes sense.
I have it figured out that even if you have a 98 car (bubble buttons) you can do this using pre 98 parts since the relay in the 98 cars have an extra wire for the two position switch. for 99 - 2k cars you would do this too and in 2k for auto down on drivers side you should just get a pre 98 harness with the auto down relay, and install it.
When you read this post does it make sense to you? I have just done it so it is clear to me, but let me know if I need to clarify.
