twocontours
if the bulb is burned out there is no voltage applied to the regulator and the alternator will not turn on.
It is just following the basics here one needs to do the checks and follow the steps. This system has some strange controls and one can not assume that a component is good just b/c it was replaced especially by a rebuilt unit. I put in two alts one NEW and one reman., the new one was bad even though it checked ok on the test. It wasn't up to the requirements for the car. The the pain was following the proceedures that finally got me to that fuse which is different for 99's of course.... LOL
But to start:
First the battery make sure it is fully charged.
Check the fuse in the BJB
Check the output of the ALT
if all these items are ok start on the trouble shooting proceedures.
Just because you have the same voltage on both sides of a fuse it could still have bad contacts and not be able to transmit enough amps thru it. Take it off and clean it at least.
Mike
...only if there was no current flowing in the circuit at the time the measurements were taken.
ANY resistance in a circuit will cause a voltage drop that is proportional to the current (Ohm's Law) and/or resistance.
Ressistor resists current!
bad fuse makes the measured voltage (in bothsides of it) to increase not decrease! (up to what it is actually, lets say 14.8 here)
like, if the voltage is measured when the fuse is completely removed, it shows the highest voltage, and -0- current.
He didn't say a bad fuse caused a voltage drop.
He said RESISTANCE in a circuit. And, to correct your statement:
a bad fuse would not make voltage "on bothsides of it" go up... that makes no sense.
A bad fuse is INFINITE resistance, and therefore there would be MAXIMUM voltage drop across that fuse. If you place your probe on the Positive terminal, and on one side of the "bad" fuse you would get 0 VDC (which means that the meter is reading a 0 volt DIFFERENCE from that side of the fuse and positive.. IE.. there is BATTERY voltage at that side (battery voltage at the battery and at that side of the fuse means a 0 volt difference)
The other side of the fuse would then read a MAXIMUM voltage (equal to Vcc/Battery voltage) Again.. the meter would be reading the DIFFERENCE in voltage, ie.. the full battery voltage would show on the meter's readout, but that is meaning that there is actually ZERO voltage at that point, because the meter is showing the DIFFERENCE.
Your statement was that a bad fuse would cause voltage to "go up" on "both sides".. this isn't physically possible.. if voltage increased (in reference) on BOTH sides of the "bad" fuse, then it wouldn't be a bad fuse.. there HAS to be a voltage drop across an open. period.
but I was talking about measuring between two ends of the fuse...
