I am trying to remove my Koni's (which I have done twice before). But this time around the nut on the top of the tower will not budge. I just spin the shaft of the strut.
In the past I was able to simply wrench it off. That being said, I was able to remove one of the two withou issue, but the passenger side is stuck.
Anyone have suggestions or methods that I may not have tried / thought of?
If I try to put a wrench on the 18mm bolt I run out of room to use another, wrench or socket above it.
I may have to get ahold of a strong impact wrench and hope that the abrupt force that it applies will snap it loose?
Thanks,
Thanks,
