Rara
Not sure if I buy the crank harmonics not being as bad at high rpm---at least thats not what I remember.
And that 4V Cobra info. is interesting---you rarely see those cranks hurt.
I respect your knowledge and you give very good information, but all the searches (and I did many on the UDP vs. DMD) never convinced me that the UDP will harm my engine. More hearsay and piling on like I see around here on various topics (my cutting springs post for ex.).
Either way, I'm running it and look forward to a decent gain at all rpm.
-J
http://www.atiracing.com/products/dampers/damper_dinan.htm
Read that. Not terribly technical, but from a respected source. And take note that few crankshafts have thier natural frequency near the engine's peak rpm, hence my statement. And I don't really care what searches you did here or anywhere on the internet, because you won't find a back to back test like you seem to imply you would need to see. That kind of testing is extremely expensive so people outside of the OEMs almost never run them. Look up things like crankshaft harmonics, and metal fatigue. I will say that the duratec does have a particularly strong crank, much like the modular 4V, but it doesn't make it immune. Plus, like I said before, with the susceptibility of the duratec to wipe rod bearings, I wouldn't want to do anything to help the process along. And again, this is nothing against UDP's, this is against UDPs that don't include a harmonic balancer.
In regards to cutting springs, I recall only saying that you shouldn't do it unless you already understand all the factors you are changing by cutting them, and you wouldn't be asking if you did.
