...Update...
*Injectors are PITA to pull out from the fuel rail. :laugh: But all tips where clean. O-rings where pretty dried out.
*LIM is off, its pretty dirty down into the head. I thought I had a bent/damaged valve on first glance inspection. The fourth cyclinder (? back, left hand side) has a huge buldge of build up on the valve.
I broke the build up off with a wooden dowel(?sp) rod.
*Plugs looked good except for 4th cyclinder, seemed to have a real light coat of oil on it, but plug was clean.
*Valve covers are not hard to take off, just a long list of things to remove. I will probably be doing some wire harness repairs to the loom since all of it was breaking where I bent it.
*Underside valve covers are clean, super clean for almost 90K in my opinion. Mild layer build up right above rockers.
*Cams and rollers look good. Only one had a visible score line on the lobe. And it was a very fine line. Lobes are worn down, but are completely smooth and appear to have a symetric wear. No visible damage to the springs, and the head is just as clean as the valve cover. A mild dark buildup where the oil would run.
*As for the trans, drain and refill, drove it around. Seems to have the same bump into gear its always had. Did not take the motor above 2800-3000 rpm. But it drove and did not have a problem getting rolling like I did Thursday afternoon (IE pedal not 3/4 to the floor).
To do:
-Decided to paint the valve covers black, since they are off, might as well go for it, and they need to be cleaned up anyway.
-Need to decide how to mount the trans cooler. Box lied! It only listed the size of the heat core itself. It neglected to mention the 3 inches of the piping wrapping aorund through the core. so instead of a 12" wide core, its more like 15" wide core. :shrug: Looks like I might have to put it in front of the radiator after all.
-Gaskets and rebuild
-Antifreeze and waterpump check
-Oil
Its gonna be a long day! :laugh:
