kidSVT
Hey, so I've been hearing some odd "poping" sounds coming from the driver's side axle area, and for a while i was convinced it was the axle. so i took it to a shop, and they heard the pop that I was talking about and confirmed it was not the axle. below is what they came up with:
1- the left lower ball joint is loose and has play. they ball joint will need to be replaced
2- the left and right front lower control arm bushings are both pushed out and should be replaced
3- the front stabilizer bar end links and bushings are both worn and loose and should be replaced
I know its hard to imagine this popping sound i'm getting, but could these things contribute to a sound like that? would this be a good time to replace the control arms?
thanks!
~Andrew
thanks!
~Andrew
