KAOS_3.0
I put that back, seemed a little silly to leave it out considering how short the bolt from it to the alternator is.
being how difficult it takes to pull an alternator out in these cars, and taking a rubber mallet to get the thing out (with the motor out and no screws lefts to hold it in) I thought I would leave it out for the next time I have to pull the ALT. out. which has come in handly cause I've already yanked it out 3 times trying to find out whats wrong with my car. Unless that bracket is some sort of ground for the regulator. just wondering cause I still have my BAT. light on and I was hoping it wasn't a ground for the regulator.I put that back, seemed a little silly to leave it out considering how short the bolt from it to the alternator is.
glad you got it in there and all fixed up. and btw I left that bracket off of all the ones i have done lol
Sweet man. Congrats. My 3l is down right now with an electrical short but we should go for a cruise some time.
Well I started it up today and it seems to be running a little better, I'm thinking it may be a voltage regulator or something. When I the revs get over 3k rpm I start to get issues and there's a high pitched electrical whine. I hope its not the alternator.
Its less than 10k old. Its not the alternator per say, but definitely charging system.
If I drive without the air on the battery light comes on around 1500 rpm, if I turn on the air, it comes on around 2500 or so. Also battery was super hot after a 15 min drive, I could hear it hissing in the trunk.
Gonna go put a voltmeter across the terminals and see what is going on when I rev it up.
Seems pretty certain its the voltage regulator which is part of the alt. Volts increase with rpms. Apparently theres a fuse to check first but unless that work out it seems like I have to pull the alternator to change it. fug.dude thats scary, I wonder if its that volt sensing wire. I wasn't getting any charge on my alt. I just did the alternator wiring fix just as a last resort and viola it fixed my problem. it may be worth a shot. maybe that wire is telling your alt to put in some overtime.
sweet jesus!
may I ask why we were driving on the median?
