00SVTGA
this month problem seems to be that the heater will only blow for about 5 minuites it will blow for 15-20 minutes sometimes when i get lucky however after that somthing cange i can hear a change in air flow and the HVAC will blow cool air no matter what the settings of the temp. controls . so i just turn it off instead of having it blow cool now its cold air in the dead of winter.
car is a 2000 csvt with very bad dash warp and 87K mileson it.
is this simply a problem with the control unit or knobs them selfs ? is there a way to fix this. no heater in the winter time sucks.
i search both heater and heat and could not find a similar post . any way to access the previous forum search engine ? i lke that set up 100x better.
