Interesting connector round concentric accordion seals around each wire. Pull the plug and meter between the BK/RD and Brn/Wh you should see steady 5vdc. (key on) wiggle the wires? I know it's abit of a juggling act. You should have 12vdc between GRN/Wh and BK/wh.
I have run into conflicting info electrical diagrams on the CD manual, involving this Brn/Wh (Signal return) lead as to how it gets back to pin 91 on the PCM connector.
If should not have 5vdc you need to check for continuity between IMRC connector and the PCM connector. As previous Brn/wh should have continuity to pin 91 and BK/rd continuity to pin 42. While your at it go to chassis ground to each end verifying no continuity/open.
Hopefully it is only a bad connector plug ie broken wire inside the plug?
I believe several others have this same issue always operated P1518?
I'm having trouble finding S48 on the engine big help it's located on the engine ---besides the Sig return from the IMRC at splice 48(partial) is wire from sig lead from O2 front #21, the engine coolant sensor I'm assuming sig return, for those with a manual tranny the TPS , the EPT sensor Exhaust pressure Transducer, and still with the manual here comes splice S53 (also on the engine?)picking up power steering pressure switch sig return. AND the ACT air charge temperature sig return (IAT maybe) and both rear O2 sig returns #12 & #22, the knock sensor sir return.
Damn I just got lost!!! Oh the ATX
For all those with P1518 could it be possible from sensor bad say going to ground or I low enough resistance to ground interacting? For those with a continuing IMRC problem if you have 5VDC on the BK-RD lead the next thing is continuity to pin 91 on PCM plug AND NO resistance readings to chassis ground OPEN. IF otherwise start unplugging all the electronic engine sensors until it's clean. Just never know the possible interactions. Maybe something to CSVT 1214's problem????? It looks like all the signal returns come back to pin 91 on the PCM.
I'll post this for now any questions please don't hesitate I know my troubleshooting/thought processes are confusing.
Does anyone know where Splice 48 and 53 are located besides on the engine? It might help someone isolate easier if they're SIG RTN lead is not clean! Tony
