Well, I ordered a Drawtite 24603 from Amazon this morning. Once it's here, I'll see what the install looks like on my 99 CSVT and post some pics in my Photobucket account. Give me a few weeks.
OK, Amazon said it might take a few weeks to ship, but they got the hitch right out and it arrived last night.
Short story, and I don't have any pictures yet, but if you have a CSVT with a stock exhaust and mufflers, do
NOT get the Drawtite 24603 or the Reese 77009. These are very wide at the ends of the cross bar, and will not clear the tailpipes coming off the mufflers.
I pulled an image out of the Towing Products instruction sheet and circled the areas where the hitch frame interferes with the tailpipes. Fixing this isn't just bending a few things or a few hammer whacks, the ends of the crossbar and the C-plates are fully 2" into the bumper cutouts for the tailpipes.
(Click thumbnail for larger image)
The drawbar receiver on the Drawtite/Reese is almost dead-nuts centered in the mesh slot of the rear bumper, so cutting to fit wouldn't be a big deal. There would be maybe a 1/2" long section of square tube poking out from the bumper cover slot, not a big deal unless your CSVT is a concourse car - mine isn't. The safety chain loops will be nicely behind the bumper cover.
Without having it in my hands and test fitting it, I think the Hidden Hitch 60979
might work, because the crossbar is shorter and won't poke into the tailpipe openings. I don't know what their drawbar receiver is going to do at the center of the CSVT bumper.
Because I have the Drawtite hitch, I'm going to cut the cross bar short at the ends and move/weld the C-shaped end plates to the inboard sides of the frame rail boxes. This will shorten up the crossbar by >2" per side, and still give all the mounting strength of the original design, probably more, because I can tie the relocated Drawtite C-plates into the OEM shipping tie-down plates that extend down from the frame boxes, as well as into the sheet metal behind the bumper beam, as Drawtite originally intended. I realize this isn't an option for a lot of you, but I'm an engineer, and I got a band saw and a TIG welder. :laugh:
